Resonant capacitor for LLC converter
cupoftea
Advanced Member level 5
We wish to use 5 ECWHA3C223 (22nF) film capacitors in parallel as a resonant capacitance in an LLC converter.
The total current is 6Arms (100kHz sine) and voltage is +/-110V again sine 100kHz.
ECWHA3C223 22nF capacitor
Do you think it'll be ok?...i dont see an actual ripple current rating in the datasheet.
For starters, 5 x 22nF = 110nF, @ 100kHz = 14.5 ohm, x 6A total = 87 Vrms = 123Vp.
--- Updated ---
D.F. = dissipation factor, Vrms * Irms * DF = watts ...
for a small cap, say 1-2cm^3, 300mW is about tops - unless you are direct force cooling ...
--- Updated Today at 10:34 AM ---
Thanks, from datasheet kindly supplied by FvM, i see DF = 0.1% at 100kHz for the 22nF.
So from your kindly given equation i am getting 87 * 1.2 * 0.001 = 100mW per cap.
This seems to be OK.
The DF was in the data sheet posted in the 1st instance too - just needed a close look - be careful that caps are suitably de-rated for voltage - if you want them to last...
--- Updated ---
Which - at 1600V part - you appear to have done ...
