slackz1987
Newbie level 2
Hi, I've searched for several guides on how to draw a resistor and capacitor layout but all the results returned in using cadence in which the layers are different from using silterra. My questions here are basically:
1. I suppose there are different types of resistors (poly, diffusion and etc?) as well as capacitors (mim, mos?) therefore, may I know what are the most basic (common) type of resistor and capacitor and their layers in Silterra ?
2. I'm having a 50 ohm resistor. For resistor, I had seen a few guides saying that the Rsheet is fixed so now I have to calculate my W and L. The W and L is for which layer and which side does it refer to as in the W = horizontal/ vertical, L = horizontal/ vertical dimension of the layer ?
3. I'm needed to draw 1 pF capacitor. How do I draw it's layout and know its value, W and L or area ?
All this layout is to be done using Silterra. Your help would be very much appreciated.
