Resistive power dividers
nnayak82
Junior Member level 3
USA
Hi folks
Here is a paper by G Adams on resistive power dividers. Can anyone please explain to me table 1 ?
The paper says if u get 1.7 db loss from port one to port 2 , u'll get 20 db loss from port 1 to port 3
can anyone derive this?
  • HFE0307_Adams.pdf
bode plots i guess
---------- Post added at 13:58 ---------- Previous post was at 13:56 ----------
the capacitor resistor combination may make a filter in this case that gives u a 20dB loss in power
Here are my analysis [Producing results which DO NOT match the values given in the table ]
Lets assume the loss from port 1 to port 2 is 1.72db . Since its a loss , I take it as -1.72db .
Using (db)=20 log V2/V1 we get V2/V1 =0.82 or V2=0.82V1
Now , this implies for a 2 way unequal power divider , V3= (1-0.82) V1 i.e. V3= 0.18V1
Converting this 0.18 into db gives -14db
Thus for a 2 port unequal resistive power divider , if S21= -1.72 db , then S31 = -14db
***The paper says S31=-20db
and also the table values do not match
It's Power Divider not Voltage Divider
Hai
Based on equations in article i get the following values of resistors:
Rs = 0.1 Zo
Rp = 5 Zo
Rt = 4.45 Zo
Ru = 1.25 Zo
So S21 would be 20log10(0.82) = -1.73 dB, as it should be,
S31 = 20log10(0.9*0.55/5) = -20 dB
So everything is correct.
Lets keep resistor values aside . Lets consider the power divider to be 3 port with port one as input port.
I was referring to a simple unequal resistive power divider and I would like to derive the value of attenuation[in db] at port 3 when we know the attenuation at port 2 .As Bigboss pointed out we are dealing with power here so my mathematical analysis are as follows :::
The author says::" 1.72 db loss at port 2 from port 1 and then we will have 20 db loss from port 1 to port 3. "
My derivation gives Since we have -1.72 db loss at port 2 from port 1 , then P2/P1 = 10^(-1.72/10) = 0.67
or P2=0.67 *P1
Assuming input power =1
1-0.67=0.33 and hence P3=0.33*P1
Or converting the ratio of P3/P1 into db yeilds -4 db and NOT 20 db as given by author
I know I might be making some mistake in above calculations and hence would like to know it .....
The obviously erronous assumption is a lossless power splitter. But by using resistors, a power divider must have losses. The amount of dissipated input power depends on the particular circuit and can't be derived from the attenuation numbers. Thus all calculations based on it are void.
You better should calculate the actual transmission factors of the given divider circuit with usual equations for resistive networks. Then you'll be able to reproduce the given numbers, as all other contributors already did. (I also checked it and could confirm).
Hai
Rs = 0.1 Zo
Rp = 5 Zo
Rt = 4.45 Zo
Ru = 1.25 Zo
I still did not understand how you calculated S31
Please explain
