Jayce
Newbie level 5
Problem: The resistance of the wire used for the telephone is 35 Ω per kilometer when the weight of the wire is 5 kg per kilometer. If the specific resistance of the material is 1.95 x 10^-8 Ω-m, (A) what is the cross-sectional area of the wire? (B) What will be the resistance of a loop to a subscriber 8 km from the exchange if wire of the same material but weighing 20 kg per kilometer is used?
From the book, the solution is:
A.)
R = 35 Ω
l = 1 km = 1000 m
p (resistivity) = 1.95 x 10^-8 Ω-m.
So from R = p(l/A) ; A = pl / A = (1.95x10^-8)(1000)/35 = 55.7 x 10^-8 sq.m.
B.)
A = (20/5)(55.7 x 10^-8) = 222.8 x 10^-8 sq. m.
Length of wire = 2 x 8 = 16 km = 16000 m
R = pl / A = (1.95 x 10^-8)(16000) / 222.8 x 10^-8 = 140.1 Ω
My question:
On part (A), even though the weight of a material does not affect the resistance (based from the formula), can we really just ignore it on the problem?
On part (B), why is 20/5 multiplied to the acquired area on the first part? Yeah, the weight from the first part is 5 kg and on the 2nd case is 20 kg, but why should we multiply it? If it is to cancel the kg unit, then shouldn't the answer on the first part have the unit of sq.m per 5 kg/km or "x-answer" at weight of 5 kg / km?
Also, on the new length of wire why did we multiply the 8 km to 2? Where did the 2 come from?
I am so confused.. any help would be appreciated. Thank you.
A.)
R = 35 Ω
l = 1 km = 1000 m
B.)
My question:
