nicklas_a74
Member level 1
I want to synthesize the design in synplify pro and use e.g. the proj.vqm file
in quartusII to setup the project and route the design.
What files exactely do I need to import in quartus from synplify?
How to being able to setup the project in quartusII by using the imported
files (so e.g. the device is selected from the imported synplify files, other constraints)?
I have tried to manually import the synplify pro files proj.vqm, proj.tcl, proj_cons.tcl
However, when I compile the quartusII it doesnt have the correct device. I have tried
tcl command e.g. source proj_cons.tcl but it doesnt work saying "project excist" or "cant open
project" depeding if I have used a created quartus II project with name proj or not!
Please give detailed help
