Represent frequency-dependent inductor in Agilent ADS?
wizardz
Member level 2
I'm doing some circuit modeling of on-chip passives.
In this work, I have to add frequency-dependent inductors to ADS. The inductance vs. freq are now available in text forms.
I guess dataaccesscomponont(DAC) can do this works. But I find simulation error when using DAC in lumped inductor setup. (I can only find examples using DAC in dataitems).
Attached is a screen shot of my circuit model
Can anyone help me or suggest some help documents?
Thanks a great!
After some investigation I find a viable way.
Insterestingly, I post reply here to answere myself.
In ADS, we can use 1-port Z-parameter component(Z-box) in eqation based linear components. The Z parameters can be read from external file.
There is a parameter set in the Z-box called Ci. This can be used to model mutual coupling. As for how to represent mutual coupling in a complex invironment, I can only think out the way of series connecting sereval Z-box, each of which have different Ci to model the multiple coupling.
I still hope someone can offer better ways!
"freq" is ADS variable and you can obtain a frequency depended inductor by using this variable such as.
L=k*freq*Linit
or similar thing..
Here k may be a coefficient or a function or something else.This equation increases (or deceases ) inductor value proportional to freqeuncy.
As I can remember, ADS can use S-parameter model in its schematic, which maintains the intrinsic frequency-dependent feature.
