curious_mind
Full Member level 4
I need to drive the relay provided in the link https://5.imimg.com/data5/SELLER/Do...speed-tripping-relays-vajh-vajs-and-vajhm.pdf.
The model is VAJHM series which has burden of 150W at 110V dc. I was looking for several options to drive the same. One constraint is that driver should be PCB mountable. It can be either solid state device or a relay. In case of a relay , what should be contact rating to drive the inductive load?
