Regarding Clock Latency and Skew?
RGR
Junior Member level 2
Hai everyone
In my project , at cts stage , after clock routing
Trail 1:
clock skew : 100ps
clock latency :600ps
Trail 2:
clock skew : 200ps
clock latency : 400ps
Which trail is better and why?
please help me.I am using ICC and encounter tool
Thank you
RGR
Hi RGR,
The trial 1 and trial 2
it depends upon following
1. what is your block size.
2. Power requirement of the block.
3. CTS structure to TOP clock structure.
Maybe you need to check for timing performance. Only then you will be able to decide.
you should also check:
1- number of the number of buffer added by the post cts setup fix
2- number of the number of buffer added by the post cts hold fix
Reactions: ivlsi
    ivlsi
I think skew should be having more priority .. which is very much important to meet. check your design specification for skew and latency limit.
Could you elaborate please (explain in details)?
