flo
Newbie level 5
Hi all,
I need to design a test platform for production of some automotive devices and I need a power supply with the following characteristics
-SMPS, to be in module form, like a classic dc-dc module converter. Time to market is critical and for few extra bucks I would like to avoid to design it from scratch, I prefer a ready made module
-most important, to have digitally controlled voltage output in the range of 3-4 up to around 40 volts. Means to control it are not important (uart interface, i2c, spi, etc), I will adjust my design according to required control method
-input is not very important as long as it is a common voltage (12/24/48 volts), also, galvanic isolation is not required
-max. required current up to 10 amps, efficiency is also not important
Can you recommend me a manufacturer of such devices?
Thank you.
Thank you.
