nyk
Hi all!!!
I wish to detect musical notes from audio sound.
For this I plan to have an analog part to first take the analog audio wave from microphone or line-in and then pre-process it.
In this pre-processing part as I have thought firstly an amplifier to amplify the low signal levels, then a filter to get the frequency band of interest
which should be from 0 Hz to say 10 KHz, then an ADC to convert the filtered output to digital samples.
After this pre-processing , the samples are processed by a DSP.
Can you suggest if the above approach in the analog part is good enough( to remove all noise) and is there a better approach so as to make the
processing in the DSP easier, or a fully analog processing based approach.
The aim is to get accurate representation of music waves from surrounding in form of digital samples.
The input is bound to acquire noise from surroundings(microphone captured audio) and from other means.
Help analog and audio guys!!!
