hi. Sorry.... or if the phone treats the USB port as a UART you could try the 'AT' command set. Hook it up, open the USB port in a terminal program and type 'AT', if it returns 'OK' you should be able to so it with the appropriate AT command. The command varies from device to device but it should be there somewhere.
Brian.
