Read data from ethernet using lpc2478
SAKU
Newbie level 5
Hello all,
I am interfacing ARM lpc2478 with the ethernet.
I am able to send data from the ARM to PC but how can i receive data from PC and store it on ARM.
The read and write operations must be controllable i.e. i should be able to read data when read() [from PC to ARM] is called and data should be written when write() [from ARM to PC] is called.
Can any one help....
-SAKU
You should find a good TCP/IP stack like lwip
Then you can use sockets for example
