From here, Rician Fading, the channel response to a sinusoid input is h(t) = C*Dirac(t - t0) + sum(rho_n * Dirac(t - tn)). For a Rician channel, C is non-zero and larger than the rho_n components. This is your direct LOS path with time delay t0. The autocorrelation of h(t) is your Ac(t,del_t) from the problem. If C is non-zero, you get a component with fixed delay in your autocorrelation function.
