[SOLVED] Random Led Blinker on DE10-lite FPGA board: [0-7]LED
chandlerbing65nm
Member level 5
Hi folks,
I have a problem with my random led blinker on fpga.
3-4 leds are turning "on" at the same time.
Although it is random, what I want is that only one led will be "on" at a time.
It seems that there is a problem with my code that the leds are overlapping there on and off states.
Before one led turns off, another led will turn on. This makes them overlap.
-- moderator added code inline --
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
// PROGRAM      "Quartus Prime"
// VERSION      "Version 16.1.0 Build 196 10/24/2016 SJ Lite Edition"
// CREATED      "Sat Feb 22 12:52:13 2020"
module WhackAMole(
    clk,
    reset,
    LED
input wire  clk;
input wire  reset;
output wire [7:0] LED;
wire    [9:0] SYNTHESIZED_WIRE_0;
blinking_leds   b2v_inst(
    .clk(clk),
    .reset(reset),
    .rnd(SYNTHESIZED_WIRE_0),
    .LED(LED));
randomnumbergenerator   b2v_inst1(
    .clk(clk),
    .reset(reset),
    .rnd(SYNTHESIZED_WIRE_0));
endmodule
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
module randomnumbergenerator (
input clk,
input reset,
output reg [9:0] rnd
wire feedback;
wire [9:0] lfsr_next;
//An LFSR cannot have an all 0 state, thus reset to non-zero value
reg [9:0] reset_value = 13;
reg [9:0] lfsr;
reg [31:0] count;
reg [31:0] counter;
// pragma translate_off
integer f;
initial begin
f = $fopen("output.txt","w");
end
// pragma translate_on
always @ (posedge clk or posedge reset)
begin
if (reset) begin
lfsr <= reset_value;
count <= 32'hF;
rnd <= 0;
end
else begin
lfsr <= lfsr_next;
count <= count + 1;
// a new random value is ready
if (count == 32'd9) begin
count <= 0;
rnd <= lfsr%8; //assign the lfsr number to output after 10 shifts
$fwrite(f,"%0d\n",rnd);
end
end
end
// X10+x7
assign feedback = lfsr[9] ^ lfsr[6];
assign lfsr_next = {lfsr[8:0], feedback};
always @ (*) begin
if (rnd == reset_value) begin
$fclose(f);
$finish();
end
end
endmodule
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
module blinking_leds (
input clk,
input reset,
input [9:0] rnd,
output [7:0] LED);
reg [31:0] counter;
reg [7:0] LED_status;
initial
    begin
    counter <= 32'b0;
    LED_status <= 0;
    end
always @(posedge clk or posedge reset)
begin
    if (reset)
        begin
        counter <= 32'b0;
        LED_status <= 0;
        end
    else if (counter > 5000000)
    begin
            case(rnd)
            10'b0000000000: LED_status[0] <= !LED_status[0];    //0
            10'b0000000001: LED_status[1] <= !LED_status[1]; //1
            10'b0000000010: LED_status[2] <= !LED_status[2]; //2
            10'b0000000011: LED_status[3] <= !LED_status[3];    //3
            10'b0000000100: LED_status[4] <= !LED_status[4];    //4
            10'b0000000101: LED_status[5] <= !LED_status[5]; //5
            10'b0000000110: LED_status[6] <= !LED_status[6]; //6
            10'b0000000111: LED_status[7] <= !LED_status[7];    //7
            endcase
            counter <= 32'b0;
    end
    else
        begin
        counter <= counter + 1'b1;
        end
end
assign LED = LED_status;
endmodule
  • top_module.txt
  • randomnumbergenerator'.txt
  • blinking_leds'.txt
Every 5 million clock cycles, you invert a random LED.
There is no code to switch off a LED when another turns on.
I think you should post your code in CODE tags instead of attachments.
I don't get why you have the rnd signal set to be 10-bits it only has 8 states so only needs 3-bits. I would get rid of the inversion of the LED_status assignments and just assign a 1'b1 to the selected LED_status and add a LED_status <= 8'b0 just before the case to ensure each time you have 5,000,002 clock cycles you will clear the last set LED and set a different LED.'
FYI it's 5,000,002 because you count from 0 to greater than 5,000,000 i.e. 5,000,001. 0-5,000,001 is 5,000,002 clock cycles.
