Garyl
Full Member level 5
I have read about this topic several times, but there is not much info about that.
I want to use old television ANALOGUE tuner as the FM receiver.
I am going to try replicate this design:
As for the start, I have browsed trough my tuners. I have selected only the analogue ones (I don't want to use I2C for now), and then selected only the ones that have pinout description on the metal case. I have looked inside them and wrote down which chips they are using.
Here they are:
Tuner SHARP VTSS 6o2
Chip: IX1018VA
Pinout:
1. BU
2. VT
3. BH
4. AGC
5. BL
6. AFT
7. B
8. IF
Tuner SHARP VTSS7 S4
Chip: IX1018VA (same as above)
Pinout:
1. BU
2. VT
3. BH
4. AGC
5. BL
6. AFT
7. B
8. IF
Tuner SAMSUNG TECC 0985VD 28A 14555437-0 (K)
Chip: TDA5330T
Datasheet supply voltage: 12V (max 14V)
Pinout:
1. BU
2. BT (I assume it's VT?)
3. BH
4. AGC
5. BL
6. AFC (same as AFT?)
7. BM (same as B?)
8. IF
Tuner TDZ-3D 000311
Chip: TDA5637T
Datasheet supply voltage: 9V (max 10.5)
Pinout:
1. BU
3. BH
4. AGC
5. BL
7. BM (same as B?)
8. IF
So now, my questions are:
1. Can anyone find IX1018VA datasheet? I need it for the supply voltage, etc...
2. What should I do with AFC pin? According to forum Search, it's the Automatic Frequency Correction, but I don't know how to connect that. Do I need to support that in order to get tuner running?
3. Is there any way to test the TV tuner IF output without attaching SAW filter and other stuff (like TA2003P)?
4. Is there any way to test the TA2003P module without TV tuner connected? I don't know, maybe put some kind of frequency generator that outputs the intermedeiate frequency of the tuner...
5. What is this "10.7MHz" part connected to Vr?
6. Where can I get 10.7MHz Ceramic Discriminator?
7. And last, are those SAWs okay? I assume that Saw must be for the exact IF Frequency, right?
Soon I will try to scavenge some more TVs or other equipment, maybe radios... and I will design a PCB for this project in Eagle and of course publish it sources here... so any suggestions and hints are welcome!
Here they are:
Chip: IX1018VA
Pinout:
1. BU
2. VT
3. BH
4. AGC
5. BL
6. AFT
7. B
8. IF
Pinout:
1. BU
2. VT
3. BH
4. AGC
5. BL
6. AFT
7. B
8. IF
Chip: TDA5330T
Pinout:
1. BU
3. BH
4. AGC
5. BL
7. BM (same as B?)
8. IF
Tuner TDZ-3D 000311
Chip: TDA5637T
Pinout:
1. BU
3. BH
4. AGC
5. BL
7. BM (same as B?)
8. IF
