kbmanick
Full Member level 1
Respected Sir,
1. i have attached you my file to your personal mail id. plz tell me how to convert it into finite gnd plane? because in fabrication we wcan use only finite gnd plane only right? how much difference will be there in the output?
2. again i am having the same doubt. see instead of giving 40 cells at six GHz, u gave 20 cells at 12 Ghz.my question is return loss is ok if u give 20 cells with6 Ghz at the same time 40 cells at 12 ghz is very good. if i change highest frequency to 10 GHz again result is different. see suppose if the resonant frequency is 5.2 GHz, can i give highest frequency as 5.3/5.4/6/7/8....? how to determine?
with thanks,
kbmani.
with thanks,
kbmani.
