Questions about clock signals in I2C slave clock
altair_06
Member level 1
Hi friends,
I need a clarification on I2C scl clock.
When I2C device acts as slave will it need any internal refference clock or input scl clock alone is sufficient to sample the data ?
1.since I2C master has the capability of controlling the scl line (pull up the scl line)
2.onother case, slave is capable of pulling down scl line when it driving data Ack in that case it need a reference time period/clock so that time it can pull down the scl line for that perilod.
3. For above two cases when developing BFM's how do we take care of clock signals.
friends u can come up with what ever the your ideas
Thanks for your time
I2C slave clock
Follow this link for i2c information.
h**p://www.robot-electronics.co.uk/htm/using_the_i2c_bus.htm
I2C slave clock
The SCL clock is very slow so preferably internal clock with higher frequency is used.
To detect START and STOP condition we need to have higher frequency sampling clock as both condition fall between positive edge.
