Question regarding simulating the DPI in QuestaSim
rayan123
Newbie level 5
Hi fellas,
I am new to this domain of DPI
I am trying to use DPI function. I have some .v files, .c files, .h files and a .so file.
I compiled .v and .c files using the command vlog -sv -dpiheader <filename_dpi.h> <filename.v> <filename_tb.v> <filename1.c> <filename2.c>
I know that i have to use the .so file in vsim command as it is the shared library.
But i am not getting the how to use it.
Any help in this regard is appreciated.
Thanks
The .so file is created by vlog if you use it to compile your C files, and then loaded automatically by vsim.
BTW, you should not use the -sv switch. Instead, use *.sv for SystemVerilog files and keep *.v for Verilog-only files.
