FreshmanNewbie
Full Member level 6
I am just starting to understand the EVSE architecture and how it will be on the PCB.
Hence, I went through this teardown video to understand the PCB architecture.
(I saw that in some questions, sharing videos is not recommended. But I searched on Google to find answers. But failed. Hence asking here).
My objective is to:
Thank you.
My objective is to:
- Understand how the main AC wires that are coming as input to the PCB, are getting converted into traces on the PCB?
- Since we have high voltage (AC mains input) and low voltage (MCU peripherals), should any from of separate ground isolation is required? If so, can somene tell me which peripherals should have the AC mains ground and which peripherals should have the digital low voltage ground and which would be the ideal location to connect these two grounds together?
Thank you.
