bhl777
Full Member level 6
Hi All,
I am new to motor and motor drive and want to ask the questions for the procedure to select the components based on the rough application requirements.
This is my example application:
1. I want to use an electric motor to lift up an object with a 1 kg weight
2. the lift speed can be constant and very slow. Say, 0.1 meter/ second
3. No need to consider the size/noise/weight/cost like the real application
Assuming the mechanical parts (the orange ones in the picture) can be well designed to fit for the application. I assume I can choose a DC motor and an appropriate motor drive to do the job. My questions are:
1. In order to find a potential motor that can be used in this application, what key motor performance spec I should look for?
2. Once the motor is selected, what is the main electrical spec I should look for to find a matched motor drive circuit?
3. If someone can point me to a real product and its drive circuits, it will be perfect.
Thank you!
Thank you!
