m_kavith
Member level 3
i m using 28 pin qfn package. in this, centre pad is the ground pin. how to ground this pin. if i routing this pin, error occurs. is it possible to add via in centre pad?
How do you know? Connecting the exposed pad may be strongly required, and thermal vias, too. For designs that have the pad connected to ground, routing the additional ground pins to it may be reasonable (unless a separate ground connection is suggested in the component datasheet). Getting errors with this connections is mainly an issue of the PCB library definition, and possibly a general problem of your layout tool.Not recommended.
