q notation for verilog
arunshanmugam46
Junior Member level 2
how to represent a floating point -3.3456 using q format .....
---------- Post added at 16:19 ---------- Previous post was at 16:18 ----------
note: using Q1.6 format (1bit-integer,1bit-sign 6bit-fractional part)
i am aware of q notation.....my doubt is how to add two Q1.6 format numbers eg:-0.8364 and -0.9127 ........
when i use 2's complement addition am getting a wrong value.......
To get the 2-complement bit pattern for negative values, add the integer range size for the format.
That is the integer close to (max value) - (min value).
For Q1.6 this is 2 - (-2) = 4.
-0.8364 + 4 = 3.1636, which is the Q1.6 2-complement value of -0.8364 with sign => 11.001010
-0.9127 + 4 = 3.0873, which is the Q1.6 2-complement value of -0.9127 with sign => 11.000110
Add and discard the "overflow" bit:
11.001010
11.000110
10.010000
The highest bit is the sign bit. It is set so the number is negative. Subtract 4 to get the decimal number:
2.25 - 4 = -1.75
Check: (-0.8364) + (-0.9127) = -1.7491
11.001010
11.000110
10.010000
2.25 - 4 = -1.75
-0.9127 + 4 = 3.0873, which is the Q1.6 2-complement value of -0.9127 is 11.000101 not 11.000110
If a number can't be expressed exactly in a given format, why are you truncating instead of rounding to the nearest value?
