pwm generation with pic micro controller
venuselectronics
Member level 2
india
dear sir,
i made one circuit for my regular use
it is like this,
i generate triangular wave form of 50 hz, after detecting zero crossing, i mean at
every zero crossing , ramp amplitude comes down to zero level, than it will charged linearaly up to set value,
than after this ramp is inverted and that inverted waveform is compared
with applied dc level ,either it is generated from 4 to 20 mA or from 0 to 10 v
,so opamp output is pwm , its pulsewidth varies with applied dc voltage from
4 to 20 mA, this pwm signal i am giving to random firing opto coupler,which drives
output scr,thus i am getting variable o/p voltage
i have modified this ckt for inductive load ,where i am using pulse transformer
instead of optocoupler, to drive pulse transformer i generate frequenct of 2
khz,after giving this frequency to AND gate ,o/p is modulated, which i am applying
to pulse transformer primary, and i am getting good result with inductive load
i want to convert this circuit with micro controller based,
can any body give me schematic where i will apply varible dc voltage to
particular pin, and get modulated output , i also want tto o/p voltage and
current on display, if possible i also want to control o/p voltage and current
through feedback
i think every body may have under stood the matter, cicuit is very large
i will post it if necessary
please provide me schematic and source code for the same
i want to use pic 16f877a , please provide me explanation for source code
venus electronics
Pic 16f877a has its own PWM generator .. you can control it by the following code written on mikroc,
void main
TRISC=0;
pwm_init=25000;
pwm_change_duty=150; // for example
pwm_start();
you can replace the "150" with any duty cycle you want from 0 to 255.
to intefrace this PWM to the inductive load ; you can use H-bridge instead of the transformer .. you can use L298 dual h-bridge.
