Push Pull Class E load location versus LC filter location
gbugh
Member level 5
Fort Worth, Texas
Most push pull class E topologies I've seen have the output L and C and load R all in series. But here Wong shows the load R across the filter capacitor of the output LC filter:
http://www.eie.polyu.edu.hk/~cktse/pdf-paper/ISCAS05-Wong.pdf
Which way is better and why, with the R (output coupling transformer) in series or with the R across the filter capacitor?
thanks, George
I think the resistor R should be in series with L and C, and not in parallel with C.
Anyway, in a Class-E amplifier matching network, if R is in parallel with C you lose more output power than placing the same R in series with L and C.
If you put R and L and C in series...
* Square waves (from the H-bridge) need to be greater amplitude.
* L needs to be greater Henry value. C needs to be lower value.
* It requires more careful tweaking of L and C to obtain sine waves. That is, to reach the ideal condition where resonant action coincides with switching transitions.
* Less waste of power (as compared to putting load in parallel with C).
So if I want to have the best efficiency I need all 3; R, L and C in series?
If I use a step up transformer to couple to the load then I don't really need a greater amplitude for the topology of RLC in series, right?
If I have a coax cable air core or very low loss core VHF transformer I shouldn't have much efficiency loss from the step up transformer, right?
Tentatively, yes. I also forgot to say series RLC can get by on less amperes, even though the incoming square waves need to be greater voltage amplitude.
My observations come from playing with simulations. Your real-life circuit may show different results.
Series LCR, 100 ohm load. Resonant frequency 50 Hz, shown at bottom right. (This readout only appears if I include the extraneous components.)
LC filter low-pass filter, similar to butterworth type (or 2nd-order bass crossover).
In the second case I think the sinewave distorts more with small changes in L or C or R.
There are numerous variations and configurations, which ought to be examined too.
Also there is the PWM sine wave method, with its own filtering requirements.
A transformer complicates things. It will require another run of simulations to get any idea about what voltage you want to come from the secondary, etc.
My simple experiments consisted of adjusting the square wave amplitude until I obtained 340 V sine peaks at the load. When I changed component values in the butterworth style LC filter, it caused large jumps in output voltage.
I guess I am not familiar enough with this type of transformer to answer.
Perhaps it applies to a class E of a different nature than I have been talking about?
I'm talking about a transformer kind of like this: **broken link removed**
with or without a core, as a core may or may not be needed depending on how high of frequency I can run the mosfets at.
The transformer would be used like in Figure 3 topology here: www.google.com/patents/US5151852
According to this xls calculator link below, for each half of the Push-Pull Class E, it looks like my source resistance will only be around 1 ohm so I'm thinking I can step the output up a by at least 1:4 if not more.
www.amwindow.org/tech/excel/ClassE_PA_design4c.xls
I was interested in the coax transformer because the greater primary surface area which would have lower losses from the skin effects at VHF frequencies.
Yes, your knowledge will have to guide you in this area. At my level of knowledge, I saw the picture of the coil and thought 'That looks just like a paper clip, and how can they charge $26.50 for it?'
