[SOLVED] push buttons
sumit garg
Junior Member level 1
like if i have two circuits , for their working there are two dfferent pushbuttons(latched)
how is it possible if one circuit is already on and i switched on second circuit by pressing push button and first circuit automatically got shut down.
show your schematic .. or at least a sketch..
Also a photo of your circuit can give good informatins. (100kBytes should be sufficient)
Klaus
Klaus
this is a simple schematics where i have 3 switches i want like if i press second switch first and third automatically got off
I fear the term "push button (latched)" can already cause confusion, because push button is commonly associated with momentary (biased) switch action.
Can you clarify if the circuit uses momentary or latched switches?
I see you want to show an "arrow sign".
I don´t recommend to do these "mechanical arrangement" in the schematic. Better use text like "Arrow up" and "Arrow down". In the schematic focus on the function. Keep the wiring clean - avoid crossings. Remove everything that is not needed. But add all electronic parts that are needed in the real circuit (like power supply capacitors). Give every part a name. It´s more clear if we talk about "SW1" than "the upper switch"
Then I recommend - before drawing a schematic - write down how you want ti to work. All the several functions and states, Use a table, a truth table, a timing diagram...
(a textual description usually is too lengthy, incomplete and confusing)
consider:
* what should happen after power up
* what if you press SW1 after power up
.. SW2 after power up
... SW3 after power up
* what do you want to happen if yu press SW2 after SW1 was pressed
.. and so on. Really every possible situation.
Then in a real circuit:
* a LED needs a current limiting resisior
* a logic output usually can not drive 5 LEDs in parallel
Klaus
its latched switch
