uC_Learner
Newbie level 3
Hi edaboarders,
I have Prolific PL2303, USB to RS232 converter, which is working fine. Now, I have to communicate to Conzerve EM6400 meter, which has 2 wire, RS485 interface. I have tried standard SN75176 based circuit connected after pl2303, but my Modbus tester software always gives 'illegal response'. Have tried different baud rates, parities, etc., but its not helping. EM6400 register map is with me and I am addressing valid registers. Also tried with and without 120R terminator resistors. One more thing, I ve tried interface circuits (after pl2303) having MAX232 + 75176 and without MAX232 (just one IC SN75176). Actually, I tried these 2 circuits directly on PC RS232 port, without prolific pl2303, but it refused to work. Just want to know, where is the problem or is there any combination left to check ? One thing that catches my mind is that EM6400 does not have a ground terminal and sometimes common ground is used in RS485, which is not there in EM6400. Is this the problem ? Any help here would be highly appreciated. Thanks in advance.
