[51] programming keil ide
tapu
Full Member level 4
india
Dear all,
I am writing a code in c in unlicensed version of keil.my code reaches to 5500 bytes.it shows errors below.
Error L250:code size limit in restricted version exceeded error L105: public refers to ignored segment.
As L250 is eval version error but what is L105?is it also eval version error? Please give reply.
Thank you for reply.I could not solve problom by keil's description of error.It also shows 'error 107:Address space overflow'. i am using 89c51.
This error message is generated when there isn't enough memory available for all the code and/or data segments in your program.
The best way to resolve this type of problem is to find out what's consuming all the memory. Look in the map (*.M51) file and locate the link map and show any as
*** ERROR 107: ADDRESS SPACE OVERFLOW
error description
Other possibility is send her your code
   #include<reg51.h>
sbit set=P1^0;
sbit mov=P1^1;
sbit inc=P1^2;
sbit dec=P1^3;
sbit ent=P1^4;
sbit alarmset=P3^7;
void all_disp();
void time_set();
void alarm_set1();
void alarm_set2();
void alarm_set3();
void alarm_set4();
void alarm_set5();
void alarm_set6();
void alarm_set7();
void alarm_set8();
void alarm_chk1();
void alarm_chk2();
void alarm_bel_HI();
void alarm_bel_LOW();
sbit e5=P1^5;//3rd e5
sbit e6=P2^3;//4th	e6
sbit e4=P1^7;//1st e4
sbit e3=P1^6;//2nd e3
#define First_Line 0x80
#define Second_Line 0xc0
#define Curser_On 0x0f
#define Curser_Off 0x0c
#define Clear_Display 0x01
#define Data_Port P0
sbit Lcd_rs = P2^0;
sbit Lcd_rw = P2^1;
sbit Lcd_en = P2^2;
sbit sda_rtc =P2^5;
sbit scl_rtc =P2^4;
/*sbit Lcd_rs = P3^5;
sbit Lcd_rw = P3^6;
sbit Lcd_en = P3^7; */
void Lcd8_Init();
void Lcd8_Command(unsigned char);
void Lcd8_Write(unsigned char,unsigned char);
void Lcd8_Display(unsigned char,const unsigned char*,unsigned int);
void Lcd8_Decimal2(unsigned char,unsigned char);
void Delay(unsigned int);
void del();
sbit SDA=P2^6;
 sbit SCL=P2^7;
 bit f;
 void Seg8_decimal2(min);
void Led8decimal2(hour);
void EEPROM_WriteByte(unsigned char eeprom_Address, unsigned char eeprom_Data);
unsigned char EEPROM_ReadByte(unsigned char eeprom_Address);
void I2C_Start();
void I2C_Stop(void);
void I2C_Ack();
void I2C_Write(unsigned char dat);
unsigned char I2C_Read();
 #define EEPROM_ID 0xa0
 void delay_ms(unsigned int ms_count);
 void I2C_NoAck();
 void I2C_Clock();
void delay_us(unsigned int us_count);
void msdelay(unsigned int value);
#define DS1307_ID 0xD0
#define SEC 0x00
#define MIN 0x01
#define HOUR 0x02
#define DAY 0x03
#define DATE 0x04
#define MONTH 0x05
#define YEAR 0x06
DS1307_get(unsigned char);
void DS1307_settime(unsigned char, unsigned char, unsigned char);
void DS1307_setdate(unsigned char, unsigned char, unsigned char);
Send2lcd(unsigned char);
void Rtc_Write(unsigned char,unsigned char);
Rtc_Read(unsigned char);
void Rtc_rd_wr_sub();
void Rtc_Init();
void Rtc_Start();
void Rtc_Tx();
void Rtc_Rx();
void Rtc_Stop();
void Rtc_Ack();
unsigned int Rtc_add_wr,Rtc_add_rd;
unsigned char d_rtc,datain_rtc,in_rtc,temp_rtc,dat_rtc,flag_rtc;
unsigned char i,j,a[10],cur=0;
unsigned char sec,hour,min,date,day,month,year,sec1,hour1,min1,sec2,hour2,min2,hh,mm,ss,dd,mn,yy,ahour,amin,asec,amin1,ahour1,ahour2,amin2,ahour3,amin3;
unsigned char amin4,ahour4,ahour5,amin5,amin6,ahour6,ahour7,amin7,ahour8,amin8,ahour9,amin9,amin10,ahour10,ahour11,amin11,ahour12,amin12,ahour13,amin13,ahour14,amin14,ahour15,amin15,ahour16,amin16,ahour17,amin17,ahour18,amin18,ahour19,amin19,ahour20,amin20,ahour21,amin21,ahour22,amin22,ahour23,amin23,ahour24,amin24;
unsigned char count[8]={0x82,0x85,0x8a,0x8d,0xc2,0xc5,0xca,0xcd};
unsigned char dec_hex(unsigned char tt)
if(tt>59)
tt+=36;
else if(tt>49)
tt+=30;
else if(tt>39)
tt+=24;
else if(tt>29)
tt+=18;
else if(tt>19)
tt+=12;
else if(tt>9)
tt+=6;
return(tt);
void all_disp()
sec = DS1307_get(SEC);
min = DS1307_get(MIN);
hour = DS1307_get(HOUR);
date = DS1307_get(DATE);
day = DS1307_get(DAY);
month = DS1307_get(MONTH);
year = DS1307_get(YEAR);
min=Send2lcd(min);
hour=Send2lcd(hour);
day=Send2lcd(day);
 Seg8_decimal2(min);
 Led8decimal2(hour);
 if(day==0x04)
Lcd8_Display(0x84,"TUESDAY: ",8);
void main()
Lcd8_Init();
 ahour=EEPROM_ReadByte(0x01);
 amin= EEPROM_ReadByte(0x02);
 asec=0;
 ahour1=EEPROM_ReadByte(0x03);
 amin1= EEPROM_ReadByte(0x04);
Lcd8_Display(0x80,"RTC TESTING: ",12);
Delay(65000);
Delay(65000);
Lcd8_Command(0x01);
Lcd8_Display(0xc0,"alarm can set:",14);
Rtc_Init();
//DS1307_setdate(0x04,0x11,0x11);
//DS1307_settime(0x16,0x00,0x00);
while(1)
all_disp();
if(day==4)
alarm_chk1();
else
alarm_chk2();
if(!set)
time_set();
if(alarmset==1)
alarm_set1();
alarm_set2();
alarm_set3();
alarm_set4();
alarm_set5();
alarm_set6();
alarm_set7();
alarm_set8();
void time_set()
all_disp();
cur=1;
while(ent)
if(mov==0)
while(!mov);
cur++;
if(cur==2)
cur=0;
else if(count[cur]==0x82)
if(inc==0)
while(inc==0);
hour++;
Led8decimal2(hour);
if(hour>=24)
hour=0;
else if(count[cur]==0x85)
if(inc==0)
while(inc==0);
min++;
Seg8_decimal2(min);
if(min>=60)
min=0;
hh=dec_hex(hour);
mm=dec_hex(min);
DS1307_settime(hh,mm,ss);
DS1307_setdate(dd,mn,yy);
void alarm_set1()
 Lcd8_Command(0x01);
 Lcd8_Display(0x84,"NOW set",7);
 Lcd8_Display(0xc0,"Regular schedule",17);
 Delay(65000);
 Delay(65000);
 Lcd8_Command(0x01);
 Lcd8_Display(0xc0,"Long alarm times",16);
  Delay(65000);
  Delay(65000);
  Lcd8_Command(0x01);
  Lcd8_Display(0x80,"1:",2);
  Lcd8_Decimal2(0x82,ahour);
  Lcd8_Decimal2(0x85,amin);
  Lcd8_Display(0x88,"2:",2);
  Lcd8_Decimal2(0x8a,ahour1);
  Lcd8_Decimal2(0x8d,amin1);
  Lcd8_Display(0xc0,"3:",2);
  Lcd8_Decimal2(0xc2,ahour2);
  Lcd8_Decimal2(0xc5,amin2);
  Lcd8_Display(0xc8,"4:",2);
  Lcd8_Decimal2(0xca,ahour3);
  Lcd8_Decimal2(0xcd,amin3);
cur=0;
while(ent)
Lcd8_Command(0x0f);
Lcd8_Command(count[cur]);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
else if(count[cur]==0x82)			                    ///1st line of lcd
if(inc==0)
while(inc==0);
ahour++;
if(ahour>=24)
ahour=0;
Lcd8_Decimal2(count[cur],ahour);
if(inc==0)
while(inc==0);
amin++;
if(amin>=60)
amin=0;
Lcd8_Decimal2(count[cur],amin);
else if(count[cur]==0x8a)
if(inc==0)
while(inc==0);
ahour1++;
if(ahour1>=60)
ahour1=0;
Lcd8_Decimal2(count[cur],ahour1);
else if(count[cur]==0x8d)
if(inc==0)
while(inc==0);
amin1++;
if(amin1>=60)
amin1=0;
Lcd8_Decimal2(count[cur],amin1);
else if(count[cur]==0xc2)
if(inc==0)
while(inc==0);
ahour2++;
if(ahour2>=60)
ahour2=0;
Lcd8_Decimal2(count[cur],ahour2);
else if(count[cur]==0xc5)
if(inc==0)
while(inc==0);
amin2++;
if(amin2>=60)
amin2=0;
Lcd8_Decimal2(count[cur],amin2);
else if(count[cur]==0xca)
if(inc==0)
while(inc==0);
ahour3++;
if(ahour3>=60)
ahour3=0;
Lcd8_Decimal2(count[cur],ahour3);
else if(count[cur]==0xcd)
if(inc==0)
while(inc==0);
amin3++;
if(amin3>=60)
amin3=0;
Lcd8_Decimal2(count[cur],amin3);
Lcd8_Command(0x0c);
Delay(65000);Delay(65000);
 EEPROM_WriteByte(0x01, ahour);
 EEPROM_WriteByte(0x02, amin);
 EEPROM_WriteByte(0x03, ahour1);
 EEPROM_WriteByte(0x04, amin1);
 EEPROM_WriteByte(0x05, ahour2);
 EEPROM_WriteByte(0x06, amin2);
 EEPROM_WriteByte(0x07, ahour3);
 EEPROM_WriteByte(0x08, amin3);
 Lcd8_Command(0x01);
void alarm_set2()
  Lcd8_Command(0x01);
  Lcd8_Display(0x80,"5:",2);
  Lcd8_Decimal2(0x82,ahour4);
  Lcd8_Decimal2(0x85,amin4);
  Lcd8_Display(0x88,"6:",2);
  Lcd8_Decimal2(0x8a,ahour5);
  Lcd8_Decimal2(0x8d,amin5);
 cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour4++;
if(ahour4>=24)
ahour4=0;
Lcd8_Decimal2(count[cur],ahour4);
if(inc==0)
while(inc==0);
amin4++;
if(amin4>=60)
amin4=0;
Lcd8_Decimal2(count[cur],amin4);
if(inc==0)
while(inc==0);
ahour5++;
if(ahour5>=60)
ahour5=0;
Lcd8_Decimal2(count[cur],ahour5);
if(inc==0)
while(inc==0);
amin5++;
if(amin5>=60)
amin5=0;
Lcd8_Decimal2(count[cur],amin5);
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x09, ahour4);
 EEPROM_WriteByte(0x10, amin4);
 EEPROM_WriteByte(0x11, ahour5);
 EEPROM_WriteByte(0x12, amin5);
  Lcd8_Command(0x01);
void alarm_set3()
 Lcd8_Command(0x01);
 Lcd8_Display(0xc0,"short alarm times",17);
  Delay(65000);
  Delay(65000);
  Lcd8_Command(0x01);
  Lcd8_Decimal2(0x82,ahour6);
  Lcd8_Decimal2(0x85,amin6);
  Lcd8_Decimal2(0x8a,ahour7);
  Lcd8_Decimal2(0x8d,amin7);
  Lcd8_Decimal2(0xc2,ahour8);
  Lcd8_Decimal2(0xc5,amin8);
  Lcd8_Decimal2(0xca,ahour9);
  Lcd8_Decimal2(0xcd,amin9);
cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour6++;
if(ahour6>=24)
ahour6=0;
Lcd8_Decimal2(count[cur],ahour6);
if(inc==0)
while(inc==0);
amin6++;
if(amin6>=60)
amin6=0;
Lcd8_Decimal2(count[cur],amin6);
if(inc==0)
while(inc==0);
ahour7++;
if(ahour7>=60)
ahour7=0;
Lcd8_Decimal2(count[cur],ahour7);
if(inc==0)
while(inc==0);
amin7++;
if(amin7>=60)
amin7=0;
Lcd8_Decimal2(count[cur],amin7);
if(inc==0)
while(inc==0);
ahour8++;
if(ahour8>=60)
ahour8=0;
Lcd8_Decimal2(count[cur],ahour8);
if(inc==0)
while(inc==0);
amin8++;
if(amin8>=60)
amin8=0;
Lcd8_Decimal2(count[cur],amin8);
if(inc==0)
while(inc==0);
ahour9++;
if(ahour9>=60)
ahour9=0;
Lcd8_Decimal2(count[cur],ahour9);
if(inc==0)
while(inc==0);
amin9++;
if(amin9>=60)
amin9=0;
Lcd8_Decimal2(count[cur],amin9);
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x13, ahour6);
 EEPROM_WriteByte(0x14, amin6);
 EEPROM_WriteByte(0x15, ahour7);
 EEPROM_WriteByte(0x16, amin7);
 EEPROM_WriteByte(0x17, ahour8);
 EEPROM_WriteByte(0x18, amin8);
 EEPROM_WriteByte(0x19, ahour9);
 EEPROM_WriteByte(0x20, amin9);
 Lcd8_Command(0x01);
 void alarm_set4()
  Lcd8_Command(0x01);
  Lcd8_Decimal2(0x82,ahour10);
  Lcd8_Decimal2(0x85,amin10);
  Lcd8_Decimal2(0x8a,ahour11);
  Lcd8_Decimal2(0x8d,amin11);
 cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour10++;
if(ahour10>=24)
ahour10=0;
Lcd8_Decimal2(count[cur],ahour10);
if(inc==0)
while(inc==0);
amin10++;
if(amin11>=60)
amin10=0;
Lcd8_Decimal2(count[cur],amin10);
if(inc==0)
while(inc==0);
ahour11++;
if(ahour11>=60)
ahour11=0;
Lcd8_Decimal2(count[cur],ahour11);
if(inc==0)
while(inc==0);
amin11++;
if(amin11>=60)
amin11=0;
Lcd8_Decimal2(count[cur],amin11);
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x21, ahour10);
 EEPROM_WriteByte(0x22, amin10);
 EEPROM_WriteByte(0x23, ahour11);
 EEPROM_WriteByte(0x24, amin11);
  Lcd8_Command(0x01);
void alarm_set5()
 Lcd8_Command(0x01);
 Lcd8_Display(0xc0,"FRIDAY schedule",17);
 Delay(65000);
 Delay(65000);
 Lcd8_Command(0x01);
  Delay(65000);
  Delay(65000);
  Lcd8_Command(0x01);
  Lcd8_Decimal2(0x82,ahour12);
  Lcd8_Decimal2(0x85,amin12);
  Lcd8_Decimal2(0x8a,ahour13);
  Lcd8_Decimal2(0x8d,amin13);
  Lcd8_Decimal2(0xc2,ahour14);
  Lcd8_Decimal2(0xc5,amin14);
  Lcd8_Decimal2(0xca,ahour15);
  Lcd8_Decimal2(0xcd,amin15);
cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour12++;
if(ahour12>=24)
ahour12=0;
Lcd8_Decimal2(count[cur],ahour12);
if(inc==0)
while(inc==0);
amin12++;
if(amin12>=60)
amin12=0;
Lcd8_Decimal2(count[cur],amin12);
if(inc==0)
while(inc==0);
ahour13++;
if(ahour13>=60)
ahour13=0;
Lcd8_Decimal2(count[cur],ahour13);
if(inc==0)
while(inc==0);
amin13++;
if(amin13>=60)
amin13=0;
Lcd8_Decimal2(count[cur],amin13);
if(inc==0)
while(inc==0);
ahour14++;
if(ahour14>=60)
ahour14=0;
Lcd8_Decimal2(count[cur],ahour14);
if(inc==0)
while(inc==0);
amin14++;
if(amin14>=60)
amin14=0;
Lcd8_Decimal2(count[cur],amin14);
if(inc==0)
while(inc==0);
ahour15++;
if(ahour15>=60)
ahour15=0;
Lcd8_Decimal2(count[cur],ahour15);
if(inc==0)
while(inc==0);
amin15++;
if(amin15>=60)
amin15=0;
Lcd8_Decimal2(count[cur],amin15);
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x25, ahour12);
 EEPROM_WriteByte(0x26, amin12);
 EEPROM_WriteByte(0x27, ahour13);
 EEPROM_WriteByte(0x28, amin13);
 EEPROM_WriteByte(0x29, ahour14);
 EEPROM_WriteByte(0x30, amin14);
 EEPROM_WriteByte(0x31, ahour15);
 EEPROM_WriteByte(0x32, amin15);
 Lcd8_Command(0x01);
void alarm_set6()
  Lcd8_Command(0x01);
  Lcd8_Decimal2(0x82,ahour16);
  Lcd8_Decimal2(0x85,amin16);
  Lcd8_Decimal2(0x8a,ahour17);
  Lcd8_Decimal2(0x8d,amin17);
 cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour16++;
if(ahour16>=24)
ahour16=0;
Lcd8_Decimal2(count[cur],ahour16);
if(inc==0)
while(inc==0);
amin16++;
if(amin16>=60)
amin16=0;
Lcd8_Decimal2(count[cur],amin16);
if(inc==0)
while(inc==0);
ahour17++;
if(ahour17>=60)
ahour17=0;
Lcd8_Decimal2(count[cur],ahour17);
if(inc==0)
while(inc==0);
amin17++;
if(amin17>=60)
amin17=0;
Lcd8_Decimal2(count[cur],amin17);
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x33, ahour16);
 EEPROM_WriteByte(0x34, amin16);
 EEPROM_WriteByte(0x35, ahour17);
 EEPROM_WriteByte(0x36, amin17);
  Lcd8_Command(0x01);
void alarm_set7()
 Lcd8_Command(0x01);
  Delay(65000);
  Delay(65000);
  Lcd8_Command(0x01);
  Lcd8_Decimal2(0x82,ahour18);
  Lcd8_Decimal2(0x85,amin18);
  Lcd8_Decimal2(0x8a,ahour19);
  Lcd8_Decimal2(0x8d,amin19);
  Lcd8_Decimal2(0xc2,ahour20);
  Lcd8_Decimal2(0xc5,amin20);
  Lcd8_Decimal2(0xca,ahour21);
  Lcd8_Decimal2(0xcd,amin21);
cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour18++;
if(ahour18>=24)
ahour18=0;
Lcd8_Decimal2(count[cur],ahour18);
if(inc==0)
while(inc==0);
amin18++;
if(amin18>=60)
amin18=0;
Lcd8_Decimal2(count[cur],amin18);
if(inc==0)
while(inc==0);
ahour19++;
if(ahour19>=60)
ahour19=0;
Lcd8_Decimal2(count[cur],ahour19);
if(inc==0)
while(inc==0);
amin19++;
if(amin19>=60)
amin19=0;
Lcd8_Decimal2(count[cur],amin19);
if(inc==0)
while(inc==0);
ahour20++;
if(ahour20>=60)
ahour20=0;
Lcd8_Decimal2(count[cur],ahour20);
if(inc==0)
while(inc==0);
amin20++;
if(amin20>=60)
amin20=0;
Lcd8_Decimal2(count[cur],amin20);
if(inc==0)
while(inc==0);
ahour21++;
if(ahour21>=60)
ahour21=0;
Lcd8_Decimal2(count[cur],ahour21);
if(inc==0)
while(inc==0);
amin21++;
if(amin21>=60)
amin21=0;
Lcd8_Decimal2(count[cur],amin21);
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x37, ahour18);
 EEPROM_WriteByte(0x38, amin18);
 EEPROM_WriteByte(0x39, ahour19);
 EEPROM_WriteByte(0x40, amin19);
 EEPROM_WriteByte(0x41, ahour20);
 EEPROM_WriteByte(0x42, amin20);
 EEPROM_WriteByte(0x43, ahour21);
 EEPROM_WriteByte(0x44, amin21);
 Lcd8_Command(0x01);
 void alarm_set8()
  Lcd8_Command(0x01);
  Lcd8_Decimal2(0x82,ahour22);
  Lcd8_Decimal2(0x85,amin22);
  Lcd8_Decimal2(0x8a,ahour23);
  Lcd8_Decimal2(0x8d,amin23);
 cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==8)
cur=0;
if(inc==0)
while(inc==0);
ahour22++;
if(ahour22>=24)
ahour22=0;
Lcd8_Decimal2(count[cur],ahour22);
if(inc==0)
while(inc==0);
amin22++;
if(amin22>=60)
amin22=0;
Lcd8_Decimal2(count[cur],amin22);
if(inc==0)
while(inc==0);
ahour23++;
if(ahour23>=60)
ahour23=0;
Lcd8_Decimal2(count[cur],ahour23);
if(inc==0)
while(inc==0);
amin23++;
if(amin23>=60)
amin23=0;
Lcd8_Decimal2(count[cur],amin23);
Lcd8_Command(0x0c);
 EEPROM_WriteByte(0x45, ahour22);
 EEPROM_WriteByte(0x46, amin22);
 EEPROM_WriteByte(0x47, ahour23);
 EEPROM_WriteByte(0x48, amin23);
  Lcd8_Command(0x01);
void alarm_chk1()
if(min==amin)
if(sec==asec)
alarm_bel_HI();
else
dec=1;
void alarm_chk2()
if(min==amin)
if(sec==asec)
alarm_bel_LOW();
else
dec=1;
void alarm_bel_HI()
dec=0;
dec=1;
dec=0;
dec=1;
void Lcd8_Init()
Lcd8_Command(0x38); //to select function set
Lcd8_Command(0x06); //entry mode set
Lcd8_Command(0x0c); //display on
Lcd8_Command(0x01); //clear display
void Lcd8_Command(unsigned char com)
Data_Port=com;
Lcd_en=1;
Lcd_rs=Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Write(unsigned char com,unsigned char lr)
Lcd8_Command(com);
Data_Port=lr; // Data
Lcd_en=Lcd_rs=1;
Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Display(unsigned char com,const unsigned char *word,unsigned int n)
unsigned char Lcd_i;
for(Lcd_i=0;Lcd_i<n;Lcd_i++)
Lcd8_Write(com+Lcd_i,word[Lcd_i]);
void Lcd8_Decimal2(unsigned char com,unsigned char val)
unsigned int Lcd_hr,Lcd_t,Lcd_o;
Lcd_hr=val%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd8_Write(com,Lcd_t+0x30);
Lcd8_Write(com+1,Lcd_o+0x30);
void Delay(unsigned int del)
while(del--);
Lcd_hr=min%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
e5=0;
P3=Lcd_t+0x30;
e5=1;
e6=0;
P3=Lcd_o+0x30;
e6=1;
Lcd_hr=hour%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
e4=0;
P3=Lcd_t+0x30;
e4=1;
e3=0;
P3=Lcd_o+0x30;
e3=1;
/*********************************LCD HEADER FILE END*************************************/
/*********************************RTC HEADER FILE START*********************************/
DS1307_get(unsigned char addr)
unsigned char ret;
Rtc_Start();
ret = Rtc_Read(addr);
Rtc_Stop();
return ret;
void DS1307_settime(unsigned char hh, unsigned char mm, unsigned char ss)
Rtc_Start();
Rtc_Write(0x00,ss); /* Write sec on RAM address 00H */
Rtc_Write(0x01,mm); /* Write min on RAM address 01H */
Rtc_Write(0x02,hh); /* Write hour on RAM address 02H */
Rtc_Stop(); /* Stop i2c bus */
void DS1307_setdate(unsigned char dd, unsigned char mm, unsigned char yy)
Rtc_Start();
Rtc_Write(0x04,dd); /* Write date on RAM address 04H */
Rtc_Write(0x05,mm); /* Write month on RAM address 05H */
Rtc_Write(0x06,yy); /* Write year on RAM address 06H */
Send2lcd(unsigned char value)
unsigned char buf1,buf2,buf = 0;
buf1 = value & 0xF0; /* Filter for high byte */
buf1 = (buf1>>4); /* Convert to ascii code */
buf2 = value & 0x0F; /* Filter for low byte */
buf=(buf1*10)+buf2;
return buf;
void Rtc_Init()//lower order 256 bytes of the chip
Rtc_add_wr=0xd0;
Rtc_add_rd=0xd1;
void Rtc_Write(unsigned char zig,unsigned char zag)// program to write to EEPROM
dat_rtc=zig;
temp_rtc=zag;
Rtc_rd_wr_sub();
above:
d_rtc=temp_rtc;
Rtc_Tx();
if (CY==1)goto above;
CY=0;
Rtc_Stop();
Rtc_Read(unsigned char zig)// program to read from EEPROM
dat_rtc=zig;
Rtc_rd_wr_sub();
Rtc_Start();
be:
d_rtc=Rtc_add_rd; // 0xd1 =Rtc_add_rd
Rtc_Tx();
if(CY==1)goto be;
Rtc_Rx();
Rtc_Ack();
CY=0;
Rtc_Stop();
return(datain_rtc);
void Rtc_Start()// must for any operation on EEPROM
sda_rtc=1;
scl_rtc=1;
sda_rtc=0;
scl_rtc=0;
void Rtc_Stop()// this is similar to the START operation whereas this should be performed after the completion of any operation
sda_rtc=0;
scl_rtc=1;
sda_rtc=1;
void Rtc_Tx()// program to send the device address, read/write address,data to be written
signed char i_rtc;
for(i_rtc=7;i_rtc>=0;i_rtc--)// should necessarily be initialised as signed char.
CY=(d_rtc>>i_rtc)&0x01;
sda_rtc=CY;
scl_rtc=1;// clock is essential inorder to write or read
scl_rtc=0;// clk should be alternated
sda_rtc=1;
scl_rtc=1;
CY=sda_rtc;
scl_rtc=0;
void Rtc_Rx()// program read the data from the EEPROM
unsigned char l_rtc;
sda_rtc=1;
for (l_rtc=0;l_rtc<=7;l_rtc++)
scl_rtc=1;
in_rtc=in_rtc<<1;
in_rtc|=sda_rtc;
scl_rtc=0;
datain_rtc=in_rtc;
in_rtc=0;
void Rtc_Ack()// this is to intimate the EEPROM that the read operation is over
sda_rtc=1;
scl_rtc=1;
scl_rtc=0;
void Rtc_rd_wr_sub()// this routine will be used by both the read & write operations to send the device address & the address at which the corresponding action is to be taken
Rtc_Start();
here1:
d_rtc=Rtc_add_wr;// 0xd0 device address is passed
Rtc_Tx();
if(CY==1)goto here1;
again1:
d_rtc=dat_rtc;// the address from which data is to be read/written is to be passed
Rtc_Tx();
if(CY==1)goto again1;
    I2C_Start();               // Start i2c communication
    I2C_Write(EEPROM_ID);      // connect to AT2404 by sending its ID on I2c Bus
    I2C_Ack();
    I2C_Write(eeprom_Address); // Select the Specified EEPROM address of AT2404
    I2C_Ack();
    I2C_Write(eeprom_Data);    // Write the data at specified address
    I2C_Ack();
    I2C_Stop();                // Stop i2c communication after Writing the data
    delay_ms(1);            // Write operation takes max 5ms, refer At2404 datasheet
  unsigned char eeprom_Data;
    I2C_Write(EEPROM_ID);      // connect to AT2404(write) by sending its ID on I2c Bus
    I2C_Ack();
    I2C_Ack();
    I2C_Write(0xA1);           // connect to AT2404(read) by sending its ID on I2c Bus
    I2C_Ack();
   eeprom_Data = I2C_Read();  // Read the data from specified address
    I2C_NoAck();
    I2C_Stop();                // Stop i2c communication after Reading the data
    delay_us(10);
  return eeprom_Data;          // Return the Read data
void I2C_Start()
    SCL = 0;        // Pull SCL low
    SDA = 1;        // Pull SDA High
    delay_us(1);
    SCL = 1;        //Pull SCL high
    delay_us(1);
    SDA = 0;        //Now Pull SDA LOW, to generate the Start Condition
    delay_us(1);
    SCL = 0;        //Finally Clear the SCL to complete the cycle
void I2C_Stop(void)
    delay_us(1);
    SDA = 0;            // Pull SDA  low
    delay_us(1);
    SCL = 1;            // Pull SCL High
    delay_us(1);
    SDA = 1;            // Now Pull SDA High, to generate the Stop Condition
void I2C_Ack()
    SDA = 0;        //Pull SDA low to indicate Positive ACK
    I2C_Clock();    //Generate the Clock
    SDA = 1;        // Pull SDA back to High(IDLE state)
void I2C_NoAck()
    SDA = 1;        //Pull SDA high to indicate Negative/NO ACK
   I2C_Clock();     // Generate the Clock
    SCL = 1;        // Set SCL */
    unsigned char i;
    for(i=0;i<8;i++)         // loop 8 times to send 1-byte of data
        SDA = dat & 0x80;    // Send Bit by Bit on SDA line
        I2C_Clock();         // Generate Clock at SCL
        dat = dat<<1;
        SDA = 1;                 // Set SDA at last
unsigned char I2C_Read(void)
    unsigned char i, dat=0x00;
       SDA=1;               //Make SDA as I/P
    for(i=0;i<8;i++)        // loop 8times to read 1-byte of data
       delay_us(1);
        delay_us(1);
        dat = dat<<1;       //dat is Shifted each time and
        dat = dat | SDA;    //ORed with the received bit to pack into byte
        SCL = 0;            // Clear SCL to complete the Clock
   return dat;               // Finally return the received Byte*
        while(ms_count!=0)
            delay_us(112);   //delay_us is called to generate 1ms delay
             ms_count--;
    while(us_count!=0)
         us_count--;
 void I2C_Clock(void)
    delay_us(1);
    SCL = 1;        // Wait for Some time and Pull the SCL line High
    delay_us(1);        // Wait for Some time
    SCL = 0;        // Pull back the SCL line low to Generate a clock pulse
try to chnage option for TARGET from SMALL to COMPACT memory model ......
89S51 have only 128byte RAM and variable in your code need 101byte if add Stack + bit + reg bank you are 6byte overflow.
Either you have to save 6 bytes of RAM or use a processor with more RAM.
You can not see whether some variables of global change on local
or shorten int to byte etc.
see on this
Thank you for Reply.
I am solving my problom according to your advise.
