lian_lee_98
Newbie level 1
Program is succesfully build but LCD not displaying anything
I am doing a project that create custom character for LCD1602, and i am using PIC16F877A, i have succesfully build the program, but by stimulating it inProteus 8, the LCD does not display anything, below is the code i wrote, the compiler i used is Hi-Tech Toolsuite C compiler, help me as i am new and i does not know where have gone wrong.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 #define _XTAL_FREQ 20000000 #define RS RD2 #define EN RD3 #define D4 RD4 #define D5 RD5 #define D6 RD6 #define D7 RD7 #include <htc.h> __CONFIG(FOSC_EXTRC &WDTE_OFF & PWRTE_ON &LVP_OFF &BOREN_ON &CPD_OFF &WRT_OFF &CP_OFF); /*******START OF LCD FUNCTIONS*********/ void Lcd_SetBit(char data_bit) //Based on the Hex value Set the Bits of the Data Lines { if(data_bit& 1) D4 = 1; else D4 = 0; if(data_bit& 2) D5 = 1; else D5 = 0; if(data_bit& 4) D6 = 1; else D6 = 0; if(data_bit& 8) D7 = 1; else D7 = 0; } void Lcd_Cmd(char a) { RS = 0; Lcd_SetBit(a); //Incoming Hex value EN = 1; __delay_ms(4); EN = 0; } Lcd_Clear() { Lcd_Cmd(0); //Clear the LCD Lcd_Cmd(1); //Move the curser to first position } void Lcd_Set_Cursor(char a, char b) { char temp,z,y; if(a== 1) { temp = 0x80 + b - 1; //80H is used to move the curser z = temp>>4; //Lower 8-bits y = temp & 0x0F; //Upper 8-bits Lcd_Cmd(z); //Set Row Lcd_Cmd(y); //Set Column } else if(a== 2) { temp = 0xC0 + b - 1; z = temp>>4; //Lower 8-bits y = temp & 0x0F; //Upper 8-bits Lcd_Cmd(z); //Set Row Lcd_Cmd(y); //Set Column } } void Lcd_Start() { Lcd_SetBit(0x00); for(int i=1065244; i<=0; i--) NOP(); Lcd_Cmd(0x03); __delay_ms(5); Lcd_Cmd(0x03); __delay_ms(11); Lcd_Cmd(0x03); Lcd_Cmd(0x02); //02H is used for Return home -> Clears the RAM and initializes the LCD Lcd_Cmd(0x02); //02H is used for Return home -> Clears the RAM and initializes the LCD Lcd_Cmd(0x08); //Select Row 1 Lcd_Cmd(0x00); //Clear Row 1 Display Lcd_Cmd(0x0C); //Select Row 2 Lcd_Cmd(0x00); //Clear Row 2 Display Lcd_Cmd(0x06); } void Lcd_Print_Char(char data) //Send 8-bits through 4-bit mode { char Lower_Nibble,Upper_Nibble; Lower_Nibble = data&0x0F; Upper_Nibble = data&0xF0; RS = 1; // => RS = 1 Lcd_SetBit(Upper_Nibble>>4); //Send upper half by shifting by 4 EN = 1; for(int i=2130483; i<=0; i--) NOP(); EN = 0; Lcd_SetBit(Lower_Nibble); //Send Lower half EN = 1; for(int i=2130483; i<=0; i--) NOP(); EN = 0; } void Lcd_Print_String(char *a) { int i; for(i=0;a[i]!='\0';i++) Lcd_Print_Char(a[i]); //Split the string using pointers and call the Char function } /*******END OF LCD FUNCTIONS*********/ const unsigned short Custom_Char5x8[] = { 0b01110,0b11011,0b10001,0b10001,0b10001,0b10001,0b10001,0b11111,//code for CGRAM memory space 1 0b01110,0b11011,0b10001,0b10001,0b10001,0b10001,0b11111,0b11111,//code for CGRAM memory space 2 0b01110,0b11011,0b10001,0b10001,0b10001,0b11111,0b11111,0b11111,//code for CGRAM memory space 3 0b01110,0b11011,0b10001,0b10001,0b11111,0b11111,0b11111,0b11111,//code for CGRAM memory space 4 0b01110,0b11011,0b10001,0b11111,0b11111,0b11111,0b11111,0b11111,//code for CGRAM memory space 5 0b01110,0b11011,0b11111,0b11111,0b11111,0b11111,0b11111,0b11111,//code for CGRAM memory space 6 0b01110,0b11111,0b11111,0b11111,0b11111,0b11111,0b11111,0b11111 //code for CGRAM memory space 7 }; int main() { unsigned int a;char i; TRISD = 0x00; Lcd_Start(); //***Load custom char inyo CGROM***// Lcd_Cmd(0x04);//set CGRAM address Lcd_Cmd(0x00);//...set CGRAM Address for (i = 0; i <= 63 ; i++) Lcd_Print_Char(Custom_Char5x8[i]); Lcd_Cmd(0); // Return to Home Lcd_Cmd(2); // .. return to Home //*** Loading custom char complete***// while(1) { Lcd_Clear(); Lcd_Set_Cursor(1,1); Lcd_Print_String("Custom Font"); Lcd_Set_Cursor(2,1); Lcd_Print_Char(0); // Display Custom Character 0 Lcd_Print_Char(1); // Display Custom Character 1 Lcd_Print_Char(2); // Display Custom Character 2 Lcd_Print_Char(3); // Display Custom Character 3 Lcd_Print_Char(4); // Display Custom Character 4 Lcd_Print_Char(5); // Display Custom Character 5 Lcd_Print_Char(6); // Display Custom Character 6 Lcd_Print_Char(7); // Display Custom Character 7 Lcd_Print_String("BATTERY"); __delay_ms(1000); } return 0; }
