Program ATF16V8B. Help!
Magadan69
Hello! I write for the first time. Excuse me for the bad English language.
I program ATF16V8B. I use program Galblast1.6. Lines L0000 - L2055 are programmed correctly. But the chip works not correctly.
In JED - a file there are even lines L2120 - L2193. I read chip contents, Galblast doesn't show these lines. It is possible to see them? Or other program?
*l00256 11111111111110111111111111111011
*l00288 11111111111111111111111110111110
*l00768 11111111101111111111111111111011
*l00800 11111111111111111111101111111110
*l01024 11111111111111111111111111111011
*l01536 11111111111111111110111111111111
*l01568 10111111111111101011111111111111
*l01600 11111010111111111011111111111111
*l01792 10111111111111101111111111111111
*l01824 11111010111111111111111111111111
*l02048 00000000001100000011000000100000
*l02112 00000000101001001111111111111111
*l02144 11111111111111111111111111111111
*l02176 111111111111111110
*c2c1e
*b8f2
It is a file which I write down in a chip.
And this, I read out from a chip.
L0256 11111111111110111111111111111011*
L0288 11111111111111111111111110111110*
L0768 11111111101111111111111111111011*
L0800 11111111111111111111101111111110*
L1024 11111111111111111111111111111011*
L1536 11111111111111111110111111111111*
L1568 10111111111111101011111111111111*
L1600 11111010111111111011111111111111*
L1792 10111111111111101111111111111111*
L1824 11111010111111111111111111111111*
N UES 0C 0C 04 00 00 00 00 00*
L2056 0011000000110000001000000000000000000000000000000000000000000000*
N PES 31 42 38 56 36 31 46 31*
C2400
*7C72
GALBlast is a hobbyist grade GAL® programmer that connects to the parallel printer port of your PC. It will program fusemaps stored in standard JEDEC files into GAL chips 16V8/A/B/C/D/Z/ZD, 18V10/B, 20V8/A/B/Z, 20RA10/B, 20XV10/B, 22V10/B/C/Z, 26CV12/B, 6001/B and 6002B manufactured by Lattice, National Semiconductors and STMicrosystems. It can not be used to program AMD PALC and PALCE, ICT PEEL or Atmel ATF chips.
if you can make programmer you can ask atmel for its programming algorithm,
I have written letter Atmel, two weeks don't answer. Can YOU have algorithm?
i have the algorithm, i got it from atmel, i send a e-mail to them asking for it they send some documents by e-mail signed and returned after that they e-mail me the files
Give me please the information. In what addresses bits "UES", "PES", "Clear", "ClearALL", "Security" for ATF16V8 lie. And, the most important thing, in what address lies "CFG" (PTD+XORn+AC1n+AC0+SYN), and in what sequence are deduced "product terms" at reading? And how it depends from PES?
