FixitFast
Junior Member level 2
Hi all,
First of all, Does One sequential PROCESS statement means 1- Clock global line ?
I have seen in some code that inside one process statement they have several IFs-else and etc. Apparently they should run in Parallel, since they are merely making a Logic element, but by the definition of process statement itself, every thing inside it runs in sequential.
Hence Lets say we have 'N' IFs-else cases in a process.
Does using multiple processes have any effect on timing or defining logic or gates consumption. I understand that in some cases the signals are to be changed in multiple IFs hence they are put inside one Process.
But what I feel comfortable with is that I want to put COMPLETELY INDEPENDETN IFs as well in the same process, since it will save me the global clock lines. Is this thing right?
Thanks
--ignore syntax please
process(clk, rst)
if rst then
elsif (rising_edge ( clk..))
if(blah blah) then
elsif...
else
end if;
if(blah blah) then
elsif....
end if;
if(blah blah) then
elsif...
end if;
Thanks
