_SquiD_
hi there,
I want to compile this code for ATMEGA 8515 with MikroC pro for avr:
and it gives me lots of errors which say that the compiler doesn't recognize some functions:
Any idea why ? please give me some advice.
Thanks in advance,
-SQD-
Added after 1 hours 51 minutes:
I fact I observed that this example is made for ATMEGA16. What modifications does this program need to work on ATMEGA8515.
-SQD-
har dat[10]; // buffer for receving/sending messages
char i,j;
sbit rs485_rxtx_pin at PORTD.B1; // set transcieve pin // PD0
sbit rs485_rxtx_pin_direction at DDRD.B1; // set transcieve pin direction
// Interrupt routine
void interrupt() org IVT_ADDR_USART_RXC {
RS485Master_Receive(dat);
void main(){
long cnt = 0;
PORTA = 0; // clear PORTA
PORTB = 0; // clear PORTB
PORTC = 0; // clear PORTC
DDRA = 0xFF; // set PORTA as output
DDRB = 0xFF; // set PORTB as output
DDRC = 0xFF; // set PORTB as output
// Pass pointers to UART functions of used UART module
UART_Wr_Ptr = UART1_Write;
UART_Rd_Ptr = UART1_Read;
UART_Rdy_Ptr = UART1_Data_Ready;
UART_TX_Idle_Ptr = UART1_TX_Idle;
UART1_Init(9600); // initialize UART1 module
Delay_ms(100);
RS485Master_Init(); // initialize MCU as Master
dat[0] = 0xAA;
dat[1] = 0xF0;
dat[2] = 0x0F;
dat[4] = 0; // ensure that message received flag is 0
dat[5] = 0; // ensure that error flag is 0
dat[6] = 0;
RS485Master_Send(dat,1,160);
SREG_I_bit = 1; // enable global interrupt
RXCIE_bit = 1; // enable interrupt on UART receive
while (1){
// upon completed valid message receiving
// data[4] is set to 255
cnt++;
if (dat[5]) { // if an error detected, signal it
PORTC = dat[5]; // by setting PORTC
if (dat[4]) { // if message received successfully
cnt = 0;
dat[4] = 0; // clear message received flag
j = dat[3];
for (i = 1; i <= dat[3]; i++) { // show data on PORTB
PORTB = dat[i-1];
} // increment received dat[0]
dat[0] = dat[0]+1; // send back to slave
Delay_ms(1);
if (cnt > 100000) { // if in 100000 poll-cycles the answer
PORTA++; // was not detected, signal
cnt = 0; // failure of send-message
if (PORTA > 10){ // if sending failed 10 times
PORTA = 0;
RS485Master_Send(dat,1,50); // send message on broadcast address
undeclared identifier 'RS485Master_Receive' in expression
undeclared identifier 'IVT_ADDR_USART_RXC' in expression
undeclared identifier 'UART_Wr_Ptr' in expression
Thanks in advance,
-SQD-
-SQD-
