Anatoliy
Hello.
I use Cadence 6.15. I created the simple design. And when I run the simulation from Analog Design Environment window, the CIW window show:
INFO (ADEXL-2107): Job 22 timed out while pending after 30 seconds
Timeouts are generally caused by a simulator nonconvergence or legitimate runtime.
Timeout duration can be modified in the 'Job Policy Setup' dialog. For no timeout, enter nothing.
INFO (ADEXL-2107): Job 23 timed out while pending after 30 seconds
and so on
Also, when I did the right click on "Job Summary" button, CIW window show:
*WARNING* Job log file not found; it is likely that the job has not started. File: /home/<name>/cds_615/projects logs_<name>/Job22.log
But when I run simulation from ADE Test Editor, it's OK.
Help me pleas to solve this problem, and sorry for my English)
Anatoliy
and so on
Anatoliy
