Singapura
Member level 3
TTL Problems
I have a PCB which I am presently troubleshooting. The portion which I
encountered some strange phenomenon is depicted in the attached
diagram.
Here, a free running oscillator clocks a counter which drives the address
of an EPROM. The data output of the EPROM is then latched to drive the
input of a DAC which then outputs a 19.2KHz sine wave. Except for the
DAC which operates from +15Vdc and -15Vdc, the rest of the circuit is
basically TTL.
In the process of monitoring the signals of this circuit, I discovered that
most of the time, the EPROM data output does not produce TTL-level
data activities. Instead, random spikes of approximately 2V were seen
and these spikes were latched to the DAC, causing the DAC to output
nothing.
The question is, for a digital device such as an EPROM, how is it possible
that random spikes can be generated at its output when it is directly
driving a latch only? Occassionally, I do obtain the desired data activities
expected but once I power off and on again, the random spikes reappear
again. What could have caused it?
Can anyone who've experienced this before give me some help?
Thanks in advance.
diagram.
basically TTL.
nothing.
Thanks in advance.
