firsttimedesigning
Full Member level 1
so i am using spectre to simulate an integrator. (please see the attached file.)
The problem is that at the output of integrator, the output voltage is around 2 MV.
R = 300k and C = 26 pF (p = 1*10^-12)
I think the reason why that the output is around 2,000,000 volts is because spectre has initial conditions set up and it places a very large resistor on top of the capacitor and so the output voltage is large.
Does anyone know how to change the resistance of that large resistor? Thanks in advance.
