problem with lm723 (simulation)
sambkn2bhu
Newbie level 6
indian
hi.. m attaching my circuit ... output is supposed to be V=Vref(1+R2/R3)... but m not getting this value... infact i cant increase my output beyond 13.45V...
hav a luk at it n pls trace out the error or watever it is !!...
thanx
i can not just leave the pin open.. it wont simulate... so i ground it... tell me if this is the real problem... n wat to do wid pin Vz !!
thanx
The V[z] pin if not used should be left unconnected, but if your simulator doesn't want to accept it that way try to shorten this pin with V[out] .. see attached picture ..
Rgds,
IanP
    sambkn2bhu
yuppp :D its working !!!
thanx IanP... you rockkkkkkk !!
Added after 4 minutes:
hey IanP.. can u also xplain y is it happening so .. !!
regards
Sameer
Connecting Vz to ground makes the zener diode limit the output voltage. I thought, it would be obvious.
In a real design, you possibly damage the chip with your circuit.
