saeedmns68
Junior Member level 1
Problem with IR2153 high side
Im making a half bridge 300v 14khz square wave power supply by using two ultra fast IGBTs and a IR2153 gate driver,when the power part of the circuit is inacvtive(Vcc=0 V) the gate-emitter waveform on high side IGBT is good with peak to peak voltage of VGE=11200mV , but when the power is activated and no load is at the output of the circuit(IC=0) the waveform will contain high frequency noise with 7000mV mixed with original waveform VPP=11.3V.bmp peak to peak ,the power supply of high and low side VGE is two isolated L7812CV output,what can be wrong in my circuit?pls help me
