Audioguru
Advanced Member level 7
- Joined
- Jan 19, 2008
- Messages
- 9,461
- Helped
- 2,152
- Reputation
- 4,304
- Reaction score
- 2,008
- Trophy points
- 1,393
- Location
- Toronto area of Canada
- Activity points
- 59,758
Heartbeat Monitor
The HeMon circuit (look in Google) does not measure the saturation of blood with oxygen. It simply gives a pulse when a spurt of blood in the finger blocks light from the LED to the LDR. The display is the number of heartbeats per minute.
The patient does not touch the circuit so it does not need strict isolation.
The LM358 is a poor quality dual opamp that operates with a single supply voltage as low as 3V and has low supply current.
In the HeMon circuit it is a simple pulse amplifier so its noise does not matter.
The diodes in your new circuit protect the AD620 from blowing up from static electricity. If an electrical short circuit occurs then the diodes would blow up and the patient will be fried and electrocuted.
The output that feeds the computer must be isolated.
