problem to find micro-controller failure?
N.Karthick
Junior Member level 2
Tirupur, India
my motor is running with help of micro-controller.
when we gives ON signal micro controller triggers the starter to ON state, motor gets turns ON, again reverse process .
yesterday i got a problem, i gave a signal to turn On the micro controller which triggers to turn On the Motor, when it accomplishing the reverse Process, Instead of turning off the Motor, it totally shutdown My Micro controller and does not work properly,
Notification: Motors does not tends to turn OFF, it is always reliable in the ON state
So Kindly prefer me a better solution to turn OFF my Motor, by preventing the Micro Controller, because when i am attempting to do this process once I face this Problem, "Micro Controller burned"
Prefer me a solution
It is doubtful that a micro controller can drive a motor directly, so what is your interface? DC motors can be a source of commutation transient voltages. Is you motor running off a separate supply?
A circuit would be helpful.
Frank
Kindly find the circuit diagram in the attachments.
This circuit runs perfectly by last 2 months, my question is, what we do when micro controller will fails? can anyone say alternate solution?
