problem on using imagecraft
arash_micro
Member level 5
Hi guys.
I'm using ICC-AVR and i can't set fuses.How to set them?
(I want to use crystal but the micro uses the internal 1M OSC)
Thanks.
Hi!
You can set the fuses in the programmer that you are using. In ICCAVR you cannot set the fuses.
However if you use the In system programmer of the ICCAVR then you can only write the fuses by writing the hex value in the space provided for the fuses.
Regards.
Thanks.but it must be a way to config fuses in the program.i'm using mega32 and in io32v.h there are some defined fuses like cksel and ckopt but i can't set or reset them.
Hi!
Yeah there must be a way of doing it. I read the iom32.h but i think that u can program the fuses in bootloader mode, as the header file has mentioned
"/* Lock and Fuse Bits with LPM/SPM instructions */"
Let me study it in a bit detail because i am also confused with that.
Regards.
