problem of vcs on linux2.4
shockie
can anybody help me about this problem. and the same script can be run well under solaris. paltform is redhat fedoral kenel linux2.4.22.
/opt/tools/vcs7.0/intel_i686_linux_2.4/lib/libvcs.a(daifind.o)(.text+0x1afb): In function `CIhash':
: undefined reference to `__ctype_b'
/opt/tools/vcs7.0/intel_i686_linux_2.4/lib/libvcs.a(daifind.o)(.text+0x1b04): In function `CIhash':
: undefined reference to `__ctype_tolower'
/opt/tools/vcs7.0/intel_i686_linux_2.4/lib/libvcs.a(pliTf.o)(.text+0x4230): In function `tf_getBaseNum':
collect2: ld returned 1 exit status
make: *** [../simv] Error 1
Make exited with status 2
CPU time: 9.080 seconds to compile + 1.140 seconds to link
I think you should try it on RH7.2.
Recompile your linux kernel maybe resolve the issue. I can use VCS7.0 on Redhat 8.0.
Please check you gcc and ld version.
Could you tell me which configure should be change in recompile procedure ind details . I just compile the new kernel 2.6.4 and the above error still in.
Tx !
Why not try Redhat 8.0? It will be ok.
I just want to know whether the different version compiler or link (GCC/LD etc.) result in this error. I notice that there two lib in $VCS_INST_DIR/intel_i686_linux_2.4/lib: libvericGCC295.X.a and libvericGCC3.2.X.a. I think these lib maybe compiled by synopsys for the same version of GCC. now I can run Modelsim5.8b and design compiler 2003.03 well on this platform and I will try other EDA tools such as prime time and formality on Fedoral core 1.
as you mentioned i will try it on redhat 8.0 later . Thanks.
In this version linux , i have install debussy 53v3 ,it work well.
LDV4.0 have the error" /lib/libsimcontrol.so: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference".
DC2002 run well.
magma have the error "/lib/ld-linux.so.2 exited with unknown exit code (139)",
so i think this version linux is no good for eda
software.
