Tom2
Full Member level 5
i try to run some examples of systemC.
When i run example fir everything it was ok.When i tried to built example risc cpu,
the executable was created but when i tried to run executable i saw the following message and the executable it was not run. (i use visual studio 2005)
Info: (I804) /IEEE_Std_1666/deprecated: positional binding using << or , is depr
ecated, use () instead.
** ALERT ** ID: initialize Architectural Registers
** ALERT ** BIOS: initialize BIOS
** ALERT ** DCU: initialize Data Cache
Error: (E115) sc_signal<T> cannot have more than one driver:
signal `STALL_FETCH' (sc_signal)
first driver `PAGING_BLOCK.port_13' (sc_out)
second driver `BIOS_BLOCK.port_6' (sc_out)
In file: ..\..\src\sysc\communication\sc_signal.cpp:126
Info: (I804) /IEEE_Std_1666/deprecated: You can turn off warnings about
IEEE 1666 deprecated features by placing this method call as the
first statement in your sc_main() function:
sc_report_handler::set_actions("/IEEE_Std_1666/deprecated", SC_DO_NOTHING);
What is the problem?????
If someone know anything please help me.
