kodi.sudar
Member level 5
Hi
I wanted to control the servo motor according to the accelerometer value ,i developed the code using Arm wizard tool ,the code works well in Proteus tool but in hardware it fails , i checked the PWM output using the Oscilloscope can you help me to rectify the problem in the code
thanks in advance
#include <LPC213x.h>
#include <math.h>
#include <stdio.h>
void input();
void adc_ini();
void adc_data();
void pwm();
void motor();
void motorzero();
void delay();
unsigned long val,adc_val;
float y,s,v,m;
float angle,b;
int main(void)
input();
pwm();
while(1)
adc_ini();
adc_data();
motor();
void input(void)
PINSEL0 = 0x00028000; /* binary: 00000000_00000010_10000000_00000000 */
IO0DIR = 0x80000000; /* binary: 10000000_00000000_00000000_00000000 */
PINSEL1 = 0x01000000; /* binary: 00000001_00000000_00000000_00000000 */
PINSEL2 = 0x00000000; /* binary: 00000000_00000000_00000000_00000000 */
IO1DIR = 0x00000000; /* binary: 00000000_00000000_00000000_00000000 */
void adc_ini(void)
PCONP = (PCONP & 0x001817BE) | (1UL<<12); /* Enable peripheral clock for ADC0 (default is enabled) */
AD0INTEN = 0x00000000; /* binary: 00000000_00000000_00000000_00000000 */
AD0CR = 0x01200202; /* binary: 00000001_00100000_00000000_00000010 */
void adc_data(void)
while((AD0DR & 0x80000000)==0); //until bit 31 is high (DONE)
val = AD0DR; //read a/d data register
adc_val = ((val >> 6) & 0x3FF); // Extract AD result
void pwm(void)
PCONP = (PCONP & 0x001817BE) | (1UL<<5); /* Enable peripheral clock for PWM0 (default is enabled) */
PWMTC = 0x00000000; /* decimal 0 */
PWMPR = 0x0000003B; /* decimal 59 */
PWMMCR = 0x00000002; /* binary: 00000000_00000000_00000000_00000010 */
PWMMR0 = 0x000003E8; /* decimal 1000 */
PWMMR2 = 0x0000004B; /* decimal 75 */
PWMMR4 = 0x0000004B; /* decimal 75 */
PWMPCR = 0x00001400; /* binary: 00000000_00000000_00010100_00000000 */
PWMTCR = 0x09; /* binary: 00001001 */
void motor(void)
if ((adc_val>=0x0000020E) && (adc_val<0x00000224))
PWMMR2 = 0x0000004C;
PWMMR4 = 0x0000004A;
PWMLER = 0x00000014;
else if ((adc_val>=0x00000224) && (adc_val<0x00000238))
PWMMR2 = 0x0000004D;
PWMMR4 = 0x00000049;
else if ((adc_val>=0x00000238) && (adc_val<0x0000024C))
PWMMR2 = 0x0000004E;
PWMMR4 = 0x00000048;
else if ((adc_val>=0x0000024C) && (adc_val<0x00000260))
PWMMR2 = 0x0000004F;
PWMMR4 = 0x00000047;
/*for negative angle*/
else if ((adc_val<=0x000001B8) && (adc_val>0x000001A3))
PWMMR2 = 0x0000004A;
PWMMR4 = 0x0000004C;
else if ((adc_val<=0x000001A3) && (adc_val>0x0000018F))
PWMMR2 = 0x00000049;
PWMMR4 = 0x0000004D;
else if ((adc_val<=0x0000018F) && (adc_val>0x0000017A))
PWMMR2 = 0x00000048;
PWMMR4 = 0x0000004E;
else if ((adc_val<=0x0000017A) && (adc_val>0x00000167))
PWMMR2 = 0x00000047;
PWMMR4 = 0x0000004F;
else
motorzero();
void motorzero(void)
void delay(void)
long int i,j,c;
for(i=0;i<400;i++)
for(j=0;j<1000;j++)
c++;
