Cesar0182
Member level 5
Greetings ... comment that I am with a small project in ISE 14.5, I have managed to synthesize but I am having compatibility problems with the ipcore fifo_generator 9.3 when implementing and I am having one of the errors.
The project is for a Virtex5 device (xc5vlx155t-3ff1136) and the code I am using is the following:
I leave attached the ipcore fifo_generator, any help is welcome. Thanks in advance.
ERROR:NgdBuild:604 - logical block 'u_client[0].U_client_ff' with type
'g1_ipcat_wbus_client_fifo' could not be resolved. A pin name misspelling can
cause this, a missing edif or ngc file, case mismatch between the block name
and the edif or ngc file name, or the misspelling of a type name. Symbol
'g1_ipcat_wbus_client_fifo' is not supported in target 'virtex5'.
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
use IEEE.std_logic_unsigned.all;
USE ieee.std_logic_misc.all;
entity g1_wbus_client_fifos_vhdl is
Port (
-- Clock and reset
i_aur_clk : IN std_logic; -- Aurora fabric clock
i_rst : IN std_logic; -- General async reset
-- wbus stack interface
o_wbus_ready : OUT std_logic;
i_wbus_wen : IN std_logic; -- wbus write enable
i_wbus_addr : IN std_logic_vector(31 DOWNTO 0); -- wbus write address
i_wbus_data : IN std_logic_vector(31 DOWNTO 0); -- wbus write data
-- 26 Client Channels
i_wbus_enable : IN std_logic_vector(25 DOWNTO 0); -- Allow writes to wbus fifo
i_wbus_fws : IN std_logic_vector(129 DOWNTO 0); -- 5-bit FIFO window select for each channel
i_wbus_clk : IN std_logic_vector(25 DOWNTO 0); -- Client clock
o_wbus_empty : OUT std_logic_vector(25 DOWNTO 0); -- fifo empty
i_wbus_ren : IN std_logic_vector(25 DOWNTO 0); -- Fifo read enable
o_wbus_count : OUT std_logic_vector(259 DOWNTO 0);-- Available data words 10 bits
--o_wbus_valid : OUT std_logic_vector(25 DOWNTO 0); -- Address and Data valid
o_wbus_wdata : OUT std_logic_vector(831 DOWNTO 0);-- Write Data 32 bits each
o_wbus_waddr : OUT std_logic_vector(831 DOWNTO 0);-- Write Address 19 bits valid
-- Status and Test Points
o_ro_wbus_debug : OUT std_logic_vector(31 DOWNTO 0);-- Output status bits for a debug register
o_test_points : OUT std_logic_vector(3 DOWNTO 0) -- test points
end g1_wbus_client_fifos_vhdl;
architecture Behavioral of g1_wbus_client_fifos_vhdl is
Component g1_ipcat_wbus_client_fifo
port(
rst : in std_logic;
wr_clk : in std_logic;
din : in std_logic_vector(51 downto 0);
wr_en : in std_logic;
full : out std_logic;
wr_data_count : out std_logic_vector(9 downto 0);
-- The Client Port is connected to all the read signals
rd_clk : in std_logic;
rd_en : in std_logic;
dout : out std_logic_vector(51 downto 0);
empty : out std_logic;
rd_data_count : out std_logic_vector(9 downto 0)
--valid : out std_logic
end component;
CONSTANT Almost_Full_Depth : std_logic_vector(9 downto 0) := "0111110100";
type wbus_count_type is array(0 to 25) of std_logic_vector(9 downto 0);
type array_26x10 is array(0 to 25) of std_logic_vector(9 downto 0);
type array_26x52 is array(0 to 25) of std_logic_vector(51 downto 0);
SIGNAL almost_full : std_logic_vector(25 DOWNTO 0);
SIGNAL ffdin : std_logic_vector(51 DOWNTO 0);
SIGNAL ff_dout : array_26x52;
SIGNAL ff_write_count : array_26x10;
SIGNAL wbus_count : wbus_count_type;
SIGNAL wbr_d : std_logic;
SIGNAL upper_adrs_match : std_logic;
SIGNAL wen : std_logic_vector(25 downto 0);
SIGNAL almost_full_d : std_logic_vector(25 downto 0);
SIGNAL wbus_addr_fws : std_logic_vector(25 downto 0);
begin
-- A fifo is implemented for each client port.
ffdin <= i_wbus_addr(19 downto 0) & i_wbus_data(31 downto 0);
-- Note: Software must monitor the level of each FIFO is some way in order to prevent
-- Almost_Full_Depth from being reached.
u_client : for idx in 0 to 25 generate
begin
o_wbus_count(10*idx+9 downto 10*idx) <= wbus_count(idx); -- Convert from 2D to 1D vector.
-- Uppermost 2 bits of 8MB Auter space must be 0's
upper_adrs_match <= '1';
-- Write only one fifo by decoding 5 address bits.
wbus_addr_fws(idx) <= '1' when (i_wbus_addr(20 downto 16) = i_wbus_fws(5*idx+4 downto 5*idx)) else '0';
wen(idx) <= i_wbus_enable(idx) and i_wbus_wen and upper_adrs_match and wbus_addr_fws(idx);
almost_full_d(idx) <= i_wbus_enable(idx) and '1' when (ff_write_count(idx) > Almost_Full_Depth) else '0';
-- partslib_pkg.vhd: Simple DFF with Clock enable e.
dc_amf: entity work.dreg_clr_vhdl generic map(1)
port map(
c => i_aur_clk,
ar => i_rst,
e => '1',
d(0) => almost_full_d(idx),
q(0) => almost_full(idx)
-- 52 bits x 512, First Word Fall Through.
U_client_ff: g1_ipcat_wbus_client_fifo
port map(
rst => i_rst, -- input rst
wr_clk => i_aur_clk, -- input wr_clk
din => ffdin, -- input [51 : 0] din
wr_en => wen(idx), -- input wr_en
full => open, -- output full
wr_data_count => ff_write_count(idx),-- output [9 : 0] wr_data_count
rd_clk => i_wbus_clk(idx), -- input rd_clk
rd_en => i_wbus_ren(idx), -- input rd_en
dout => ff_dout(idx), -- output [51 : 0] dout
empty => o_wbus_empty(idx), -- output empty
rd_data_count => wbus_count(idx) -- output [9 : 0] rd_data_count
--valid => o_wbus_valid(idx) -- output valid
-- o_wbus_waddr is divided into 32 bit widths for convenience
-- even though only the lowest 19 bits are used.
o_wbus_waddr(32*idx+31 downto 32*idx) <= "0000000000000" & ff_dout(idx)(50 downto 32);
o_wbus_wdata(32*idx+31 downto 32*idx) <= ff_dout(idx)(31 downto 0);
end generate u_client;
wbr_d <= NOT OR_REDUCE (almost_full);
dc_wbr : entity work.dreg_clr_vhdl generic map(1)
PORT MAP (
c => i_aur_clk,
ar => i_rst,
e => '1',
d(0) => wbr_d,
q(0) => o_wbus_ready);
-- This output port is for a diagnostic register to read back the 'almost_full' flag of each client fifo.
o_ro_wbus_debug <= X"E" & "00" & almost_full(25 DOWNTO 0); --The '0xE' in the msb nibble is just for
-- identifying purposes.
o_test_points <= x"0";
end Behavioral;
