[SOLVED] Problem Enabling External Interrupts
rallysteve
Newbie level 6
I have created this piece of code from two smaller pieces of code I have been working on, one to do Analogue to Digital Conversions and the other to deal with interrupts and send data through the serial port. I have combined the two programs 99% sucessfully except for problems enabling the external interrupts.
The System reads the 8 A/D channels on the Atmel 89C51CC03 (I know the include file is for CC01 but if i change it to CC03 I get loads of errors :shock: ) the system then outputs the 8 bit value of each channel through the Serial Port with a start and stop bit.
When assembling in Keil uVision 4 I get the following error "test.a51(44): error A17: INVALID BYTE BASE IN BIT ADDRESS EXPRESSION" However this instruction worked fine before I added the A/D conversion code to it and im not sure what the problem is now??
I have commented the four lines below out and the program compiles and runs nicely in simulator except for the fact the interrupts wont trigger (presumably as they have not been Enabled!):
	SETB	IE.0			; Enable External Interrupt 0
		SETB	IE.2			; Enable External Interrupt 1
		SETB	IE.7			; Global Interrupt Enable
		SETB	IP.0			; Set Priority of Interrupt 0 higher than 1
My full code is seen below, any help much appreciated cheers Steve
/*   Transmitter Program - Steven Newton A813349 - Stage Lighting Controller - Part D Project 	*/
$NOMOD51 						; Ask Keil not to define 8051 registers
$INCLUDE (t89c51cc01.INC)		; Include file
value_converted DATA 10H; 		; Conversion Value
AD_0   DATA		11H				; Channel 0 Data
AD_1   DATA		12H				; Channel 1 Data
AD_2   DATA		13H				; Channel 2 Data
AD_3   DATA		14H				; Channel 3 Data
AD_4   DATA		15H				; Channel 4 Data
AD_5   DATA		16H				; Channel 5 Data
AD_6   DATA		17H				; Channel 6 Data
AD_7   DATA		18H				; Channel 7 Data
end_of_convertion BIT 20H; 		; End of Conversion Flag
ORG		00000H
START:
		JMP		SETUP
ORG		00003H
		JMP		INT_1		    ; Interrupt 1 (MB)	P3.2
ORG		00013H
		JMP		INT_2			; Interrupt 2 (Hold)  P3.3
ORG		00043h
		LJMP    adc_it			; Save Conversion Value
ORG		00050H
		LJMP	SETUP
ORG		00100H
		SJMP	BEGIN
SETUP:
/* Setup Hardware Interrupts */
BEGIN:
/* Set Up ADC and UART */
		MOV 	ADCF,#0C0h		;
		MOV 	ADCLK,#06h		; Fosc = 16 MHz, Fadsc = 153.8khz
		MOV 	ADCON,#20h		; Enable the ADC
		SETB 	EA				; enable interrupts
		SETB 	EADC			; enable ADC interrupt
		MOV		SCON,#050H	   	; Mode 1, 8 Bit UART, Variable baud rate
		MOV		TMOD,#020H		; TImer 1, Mode 2, 8-Bit Auto Reload
		MOV		TH1,#0F4H	   	; Reload Value for 2400Baud @ 11.0592MHz
		SETB	TR1				; Set Timer to run
		SETB	TI				; Set Ti ready to send 1st charactor
		SETB	TCON.1			; Level Sensitive Input
LOOP:
/* 	 Channel 0  */
		ANL 	ADCON,#~07h				; Clear the channel field ADCON[2:0]
		ORL 	ADCON, #00h				; Select channel 0
		ANL 	ADCON,#~40h				; standard mode
		ORL 	ADCON, #08h				; Start conversion
		JNB 	end_of_convertion,$		; Wait end of convertion
		CLR 	end_of_convertion		; Clear software flag
		MOV 	AD_0,value_converted	; Save converted value
/* 	 Channel 1  */
		ORL 	ADCON, #01h				; Select channel 1
		MOV 	AD_1,value_converted	; Save converted value
/* 	 Channel 2  */
		ORL 	ADCON, #02h				; Select channel 2
		MOV 	AD_2,value_converted	; Save converted value
/* 	 Channel 3  */
		ORL 	ADCON, #03h				; Select channel 3
		MOV 	AD_3,value_converted	; Save converted value
 /*  Channel 4  */
		ORL 	ADCON, #04h				; Select channel 4
		MOV 	AD_4,value_converted	; Save converted value
/* 	 Channel 5  */
		ORL 	ADCON, #05h				; Select channel 5
		MOV 	AD_5,value_converted	; Save converted value
/* 	 Channel 6  */
		ANL 	ADCON,#~07h				; Clear the channel field ADCON[2:0] */
		ORL 	ADCON, #06h				; Select channel 6 */
		ANL 	ADCON,#~40h				; standard mode */
		ORL 	ADCON, #08h				; Start conversion */
		JNB 	end_of_convertion,$		; Wait end of convertion */
		CLR 	end_of_convertion		; Clear software flag */
		MOV 	AD_6,value_converted	; Save converted value */
/* 	 Channel 7  */
		ORL 	ADCON, #07h				; Select channel 7 */
		MOV 	AD_7,value_converted	; Save converted value */
SEND_DATA:
/* Send Converted Data for 8 Channels to Serial Buffer with Start and Stop Bits */
		MOV		R1,#02BH		; Preload R1 with start bit	 (+)
		MOV		SBUF,R1			; Load Start Bit into Serial Buffer
		CLR		TI				; Clear Charactor sent flag
		CALL	WAIT			; Wait for charactor to be set
		MOV		SBUF,AD_0		; Load Channel 0 into Serial Buffer
		CLR		TI
		CALL	WAIT
		MOV		SBUF,AD_1		; Load Channel 1 into Serial Buffer
		CLR		TI
		CALL	WAIT
		MOV		SBUF,AD_2		; Load Channel 2 into Serial Buffer
		CLR		TI
		CALL	WAIT
		MOV		SBUF,AD_3		; Load Channel 3 into Serial Buffer
		CLR		TI
		CALL	WAIT
		MOV		SBUF,AD_4		; Load Channel 4 into Serial Buffer
		CLR		TI
		CALL	WAIT
		MOV		SBUF,AD_5		; Load Channel 5 into Serial Buffer
		CLR		TI
		CALL	WAIT
		MOV		SBUF,AD_6		; Load Channel 6 into Serial Buffer
		CLR		TI
		CALL	WAIT
		MOV		SBUF,AD_7	    ; Load Channel 7 into Serial Buffer
		CLR		TI
		CALL	WAIT
		MOV		R1,#020H		; Preload R1 with end bit (SPACE)
		MOV		SBUF,R1			; Load R1 into the Serial Buffer
		CLR		TI
		CALL	WAIT			; Clear Charactor sent flag
		JMP		LOOP
WAIT:	JNB TI,WAIT				; Wait for Charactor to be sent
		RET						; Return to
INT_1:
/* Interrupt to Trigger Master Black Out */
		PUSH	PSW				; Push Program Status Word to the Stack
		CLR		P2.0			; Turn on the Master Blackout LED
		MOV		A,#042H			; Load the letter B into Accumulator
		MOV		SBUF,A			; Load data into Serial Buffer
		CLR		TI				; Clear the Charactor Sent Flag
WAIT1:	JNB 	TI,WAIT1		; Wait for Charactor to be sent
		SETB	P2.0			; Turn off the Master Blackout LED
		POP		PSW				; Pop Processor Data from the Stack
		RETI					; Return from interrupt routine
INT_2:
		CLR		P2.1			; Turn on the Hold LED
		MOV		A,#048H			; Load the letter H into Accumulator
WAIT2:	JNB 	TI,WAIT2		; Wait for Charactor to be sent
		SETB	P2.1			; Turn off the Hold LED
ADC_IT:
		ANL 	ADCON,#~10h       			; Clear the End of conversion flag
		MOV 	value_converted,ADDH       	; Save value
		SETB 	end_of_convertion;        	; Set flag
		RETI								; Return from Interrupt
END
Problem was due to different names given to interrupt bits in definition file (from Atmel) compared with that provided by the Keil uVision. Changed the names in the definition file and now works perfectly.
Steve
