[Problem] clock_gating_cell in SCAN insertion
wjccentury
Junior Member level 2
Hello everybody !
I am doing scan insertion under 65nm using DFT Compiler XG mode. When I finished the scan insertion, I checked the dft_drc report before and after scan.
In dft_drc_before_scan.rpt:
There is a warning TEST-121 said a clock_gating_cell can't be made scannable because it is dont_touched.
In dft_drc_after_scan.rpt:
No TEST-121 warning and the test coverage is good.
Then I removed the dont_touch attribute of this clock_gating_cell, but the result was the same.
Then I checked the library information, I found the attribute of this clock_gating_cell included "b, s, d, cg", that is black_box, stable, dont_use and clock_gating_cell.
I think the reason for TEST-121 may be caused by the black_box attribute of this cell.
Am I right? I hope somebody can give ma a hand !!!
Thank you very much !!!
By default clk-gating cells are dont toch.
you need to set this as
remove _attribute dont use
