eehadi
Newbie level 5
Hi. I have a problem using RS485.
I can transmit data using RS485 (ISL83485 IC) and receive it while only one receiver is connected, but when I connect both receivers, I can't receive data correctly in the farther device (located about 2 meter far from sender).
Am I wrong about connecting more than one device to sender or the transmitter IC can't support enough current. I connected R+, R- of two receivers directly to D+, D- of transmitter. is any resistor needed?
