Hello, I have this faulty Power Transformer (see attached picture for body marking). I tried to source vendors but not help. I tried to google the body marking also cannot find. Need your help. Thank you very much.
A high frequency SMPS transformer, most likely custom made for the specific product. Unlikely to find a replacement by part number. How do you even know it's faulty?
Hello, thank you very much for your reply. Its coil has been measured with Blue Ring Tester (below picture; None LED light on indicating coil short) after measuring the coil resistance ok.
Unless you have a specification of the accepted Q and L range of the tester, I would be cautious to decide about transformer health state. If the transformer has a winding short, it should be indicated for all windings.
Apart from test result interpretation, there's still the question of finding a replacement.
Hello, I am checking the specification of accepted Q and L range of the tester. I measured the windings with LCR Meter. Please comment. Thank you very much.
