maormat4
Junior Member level 3
Hello my friends,
i have some questions (some of them are wired):
1) What is the prefferd way to work? discontinous mode or continous mode?
2) what is the different between voltage feedback and current feedback?
3) assume i have 3 power supply modules connected in parallel using oring diodes, the output voltage will be a voltage that one of the oring diodes will be reversed biased, so one module will not work?
4) If i have a battery that doesnt connected to anything, the battery have parastic resistance so she some day will discharged. but, the air have a resistance so the battery will discharge throw the air too (in a very low current)? so its mean that the battery will discharge from all the universe and she make a current to flow all over the universe (a very very small current)?
5) If i have a battery of 5V and the negitive terminal is connected to ground and the positive terminal is connected to diode chatode, and the anode of the diode is disconnected, what will be the voltage at the anode?
Thank you my friends
