David_
Advanced Member level 2
Hello.
I've got a decision to make regarding the power supply topology for my lab power supply, ether I stick with a center-tapped transformer that generates a 0 to +30 rail and a 0 to -30V rail or I'll simplify the design somewhat since I have some time ago opened up the transformer and split the center-tap I could go for two identical floating 0 to +30V rails that could be connected to result in +30V/-30V. It would only need one extra digital isolator for the digital control signal to separate the common planes, but
Is there any pros in keeping it +/-30V?
And is there any cons in doing it the double floating channel way?
The circuits will need a -3V supply each, I have just begun to research the options for that but that might be a problem.
I appreciate all kinds of input.
