Raady Here
Full Member level 5
hi,
what is the module called that is used in laptops when plugged in it uses power supply and when disconnected it uses battery.
I have motor parameters analyzer where I use 9v 1a supply, I want to make it portable so that when i disconnect it from supply it should run by battery and when plugged in it should use power supply.
i have gone through MCP73871 but it doesnt suit my application(I use 9v 1a supply now).
Regards,
Raady
Regards,
Raady
